Passing digest credentials to http-request node
Hi ,
I am struggling with using the stock http-request node
You can set URL and METHOD with msg properties but not authentication options
I have a flow that pulls the url, method and credentials
This works fine with basic because I can set headers in a change node
I understand Digest is more complicated and can use crypto-js node to create a digest hash but it isnt just the password that is hashed
Can anyone point me towards info to either edit the stock http-request node to accept credentials via msg or a function to build the digest header before send msg to http-request
End result is would like a dashboard that can request still images from several image stores that use different methods and credentials so these can not be static
Any guidance welcome
Stephen
If the credentials need some processing (digest hash before adding them to msg.headers) then, as you noticed also, you'll need a Function node. If you need the crypto-js library for that then you can require it using functionExternalModules option.
Using the functionExternalModules option
Thanks UnborN
You are correct that I would use a function node with crypto-js as external module but I am looking for more information regarding the hash construction that http-request uses as it is perfectly functional when I can use credentials statically
How to build a http digest hash are in the http RFCs documents
Specifically RFC 7616 - HTTP Digest Access Authentication
Awesome
Exactly what I was looking for
A beer for you sir
