For some reason NR Dashobard 2.0 fails to render a class set by my incoming msg.style
If I replace {{msg.sub[0].style}} with static class name, it works.
Why?
In Vue you have to use v-bind or the shorthand : on the class and single curly brackets in order for
msg.sub[0].style to be considered as code (Vue documentation)
<div :class="{msg.sub[0].style}"></div>
im not sure but i think in vue you use { } only in the case of class
in the case of :title try without the single brackets :title="msg.payload"
ps. I havent tested it .. in these cases its better to copy / paste you code in text form instead of screenshot .. makes it easier for us to copy use the code
Thank you, that explained a lot ![]()
:title="msg.main?.articlename"
: before the attribute tells Vue "there is some dynamic functionality in here, go and compute it"? is required because on first load the msg.main will not be equal to anything, so it will be trying to read .articlename of undefined.{}, the : tells Vue it's JavaScript.Note: I've assumed here yu're sending msg.main and not msg.payload is is more common.
You are trying to add a variable to CSS, this will not work.
You need 2 classes in your HTML, 1 with the basic status and a second bound to the variable with the colour.
This is an example of ONE way of doing this, there are many others
<v-btn class = "status" :class = "colourClass" </v-btn>
Have a look at some of the examples Text ui-template | Node-RED Dashboard 2.0 (flowfuse.com)
Thanks for reply.
I have to create a new class for every color?
I'm asking this because, actually, I'm migrating from dashborad 1.0 to 2.0, and I got a lot of situations that I can do this in template node. Something like this is possible and works well in 1.0:
<p>
<span class="cardSpan">
<span style="color:{{msg.colores}};font-weight: bold;vertical-align: middle;display: inline-block;font-size: 20px;">Status: {{msg.status}} </span>
</span>
</p>
I have a special color for every possible "status" (its a string to info the current machine state) that msg.colores is defined in a function node with a "switch case" before the template node.
For 2.0, to replace this "logic" for dynamically change "status" string color I have to create a new class for every colors, its that right? Can you describe other way to do that (sorry, I cant really understand that ones on the link)?
@raullink you need to v-bind the style by adding the shorthand : infront of it if you are planning to send dynamic styles to it .. along with some other small changes as per the example below
<template>
<p>
<span :style="{ 'color':msg.payload?.color, 'font-weight': 'bold', 'vertical-align': 'middle', 'display': 'inline-block', 'font-size': '20px' }">Status: {{msg.payload?.status}}</span>
</span>
</p>
</template>
Test Flow :
[{"id":"fe1b74cba6ca339d","type":"inject","z":"54efb553244c241f","name":"error - red","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"{\"color\":\"red\",\"status\":\"Error\"}","payloadType":"json","x":160,"y":2260,"wires":[["f332963bc60e072d"]]},{"id":"f332963bc60e072d","type":"ui-template","z":"54efb553244c241f","group":"12caf9e6968092fd","page":"","ui":"","name":"","order":0,"width":"6","height":"1","head":"","format":"<template>\n <p>\n <span class=\"cardSpan\">\n <span :style=\"{ 'color':msg.payload?.color, 'font-weight': 'bold', 'vertical-align': 'middle', 'display': 'inline-block', 'font-size': '20px' }\">Status: {{msg.payload?.status}}</span>\n </span>\n </p>\n</template>","storeOutMessages":true,"passthru":false,"resendOnRefresh":true,"templateScope":"local","className":"","x":340,"y":2300,"wires":[["05b95dd9b1009de3"]]},{"id":"05b95dd9b1009de3","type":"debug","z":"54efb553244c241f","name":"debug 59","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":560,"y":2300,"wires":[]},{"id":"060dea938c81d552","type":"inject","z":"54efb553244c241f","name":"OK - green","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"{\"color\":\"green\",\"status\":\"OK\"}","payloadType":"json","x":160,"y":2340,"wires":[["f332963bc60e072d"]]},{"id":"12caf9e6968092fd","type":"ui-group","name":"Group 1","page":"1a89c4c21097111f","width":"6","height":"1","order":-1,"showTitle":true,"className":"","visible":"true","disabled":"false"},{"id":"1a89c4c21097111f","type":"ui-page","name":"Page 1","ui":"d726187aa6c1921a","path":"/","layout":"grid","theme":"b5afc19a78309829","order":1,"className":""},{"id":"d726187aa6c1921a","type":"ui-base","name":"UI Name","path":"/dashboard"},{"id":"b5afc19a78309829","type":"ui-theme","name":"Theme Name","colors":{"surface":"#ffffff","primary":"#008000","bgPage":"#eeeeee","groupBg":"#ffffff","groupOutline":"#cccccc"}}]
It works flawlessly. Thanks!
