Payload object with "-" in the name does not work
Hi all,
when i retrive the wps status from a Fritz!Box i get the payload:
{"NewX_AVM-DE_WPSMode":"stop","NewX_AVM-DE_WPSStatus":"err_timeout"}
to display the values i have split node:
var Mode = {payload: msg.payload.NewX_AVM-DE_WPSMode};
var Status = {payload: msg.payload.NewX_AVM-DE_WPSStatus};
return [Mode,Status];
here comes the error:
ReferenceError: DE_WPSMode is not defined (line 1, col 43)
the first part of the payload object is not read. Is there a option to rename the part of payload object or how to get the right value?
Thanks to all
Hubertus
When JavaScript sees msg.payload.NewX_AVM-DE_WPSMode it interprets it as:
msg.payload.NewX_AVM - DE_WPSMode
In other words, it tries to subtract the value of the variable DE_WPSMode from msg.payload.NewX_AVM, but as DE_WPSMode doesn't exist, you get the error you see.
To access that object property, you'll have to use the alternative syntax:
msg.payload["NewX_AVM-DE_WPSMode"]
Hi knolleary,
thank you for the fast answer!
it works! perfekt.
