Payload values to CSS variable
I need to put msg.kylmäpiste and msg. lämpöpiste into root variables to move corresponding balls in the flow
template node
<div id="bgr">
    <div class="txt" id="txt1">{{msg.s1}}</div>
    <div class="txt" id="txt2">{{msg.s2}}</div>
    <div class="txt" id="txt3">{{msg.s3}}</div>
    <div class="txt" id="txt4">{{msg.s4}}</div>
    <div class="txt" id="txt5">{{msg.s5}}</div>
    <div class="txt" id="txt6">{{msg.s6}}</div>
    <div class="txt" id="txt7">{{msg.s7}}</div>
    <div class="txt" id="txt8">{{msg.s8}}</div>
    <div class="ball" id="ball1"></div>
    <div class="ball" id="ball2"></div>
</div>
<style>
.ball{
    position:absolute;
	width: 40px;
	height: 50px;
	border-radius: 50%;
#ball1 {
	margin: 25px 1360px;
    background-color:blue
#ball2 {
	margin: 25px 360px;
    background-color:red
I try this and many other ones. Surely simple to fix :wink:
:root {
 --lämpöpiste : {{msg.lämpöpiste }};
 --kylmäpiste : {{msg.kylmäpiste }};
.ball{
    position:absolute;
	width: 40px;
	height: 50px;
	border-radius: 50%;
#ball1 {
	margin: 25px var(--kylmäpiste)px;
#ball2 {
	margin: 25px var(--lämpöpiste)px;
Here's one solution how the CSS variables can be set and changed dynamically with the incoming message.
[{"id":"e75ed9b136aac959","type":"inject","z":"9141c3fbcc7d9e2b","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"{\"a\":30,\"b\":40}","payloadType":"json","x":350,"y":3060,"wires":[["6b20bc688347d6cd"]]},{"id":"1e81cc1e8d565bad","type":"inject","z":"9141c3fbcc7d9e2b","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"{\"a\":70,\"b\":20}","payloadType":"json","x":350,"y":3120,"wires":[["6b20bc688347d6cd"]]},{"id":"6b20bc688347d6cd","type":"ui_template","z":"9141c3fbcc7d9e2b","group":"f6124e036e2d2ffb","name":"","order":10,"width":0,"height":0,"format":"<div class=\"container\" id=\"{{'container_'+$id}}\" style=\"--variable_1:50; --variable_2:50\">\n    <div class=\"dot\"></div>\n</div>\n<style>\n    .container {\n        display: contents;\n    }\n\n    .dot {\n        width: calc(var(--variable_1) * 1%);\n        height: calc(var(--variable_2) * 1%);\n        background: red;\n    }\n</style>\n<script>\n    (function(scope) {\n        scope.$watch('msg', function(msg) {\n        if (msg) {\n        // Do something when msg arrives\n            document.getElementById(\"container_\"+scope.$id).style.setProperty('--variable_1', msg.payload.a);\n            document.getElementById(\"container_\"+scope.$id).style.setProperty('--variable_2', msg.payload.b);\n        }\n    });\n})(scope);\n</script>","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":true,"templateScope":"local","className":"","x":540,"y":3080,"wires":[[]]},{"id":"f6124e036e2d2ffb","type":"ui_group","name":"Default","tab":"34ab7d39f3e308fc","order":1,"disp":true,"width":"5","collapse":false,"className":""},{"id":"34ab7d39f3e308fc","type":"ui_tab","name":"Home","icon":"dashboard","order":2,"disabled":false,"hidden":false}]
cant get working...
tempate
<script>
    (function(scope) {
        if (msg) {
            document.getElementById("container_"+scope.$id).style.setProperty('--lämpöpiste', msg.payload.a);
            document.getElementById("container_"+scope.$id).style.setProperty('--kylmäpiste', msg.payload.b);
})(scope);
</script>
    <div class="container" id="{{'container_'+$id}}"  style="--kylmäpiste:1360; --lämpöpiste:360">
</div>
<style>
.ball{
    position:absolute;
	width: 40px;
	height: 50px;
	border-radius: 50%;
#ball1 {
#ball2 {
.container{
  background-color: antiquewhite;
  background-image: url("/Pictures/tikkuvaaka.png");
  background-size: contain;
  background-repeat: no-repeat;
  position:relative;
  width:100%;
  height:100%;
  z-index:0;
.txt{
    color:red;
    font-weight:bold;
#txt1 {
    position: absolute;
    left: 225px;
    top: 120px;
    font-size:25px;
#txt2 {
    position: absolute;
    left: 395px;
    top: 120px;
    font-size:25px;
#txt3{
    position: absolute;
    left: 545px;
    top:120px;
    font-size:25px;
#txt4{
    position: absolute;
    left: 710px;
    top: 120px;
    font-size:25px;
#txt5{
    position: absolute;
    left: 870px;
    top: 120px;
    font-size:25px;
#txt6{
    position: absolute;
    left: 1020px;
    top: 120px;
    font-size:25px;
#txt7{
    position: absolute;
    left: 1180px;
    top: 120px;
    font-size:25px;
#txt8{
    position: absolute;
    left: 1360px;
    top: 120px;
    font-size:25px;
</style>
In many cases, using the variable and combining it with the units do need calculation in css.
Use browser developer tools and search for computed styles for element to make sure it actually works.
This will be 0px margins in all directions
Use calc() to make it working
margin: 25px calc(var(--kylmäpiste) * 1px)
Thanks!
Now works...
