Hi Guys, I am trying to convert a pdf to image using the pdf-image (pdf-image - npm) package. I have installed the dependencies and modified the settings.js file accordingly. No errors during restart. The challenge I have now is that when using the package in a function node I get a "TypeError: PDFImage is not a function" error. Code in function node is only:
var PDFImage = global.get('pdf-image');
var pdfImage = PDFImage(msg.payload);
Any ideas would be much appreciated. Thanks
The readme says...
var PDFImage = require("pdf-image").PDFImage;
var pdfImage = new PDFImage("/tmp/slide.pdf");
pdfImage.convertFile().then(function (imagePaths) {
// [ /tmp/slide-0.png, /tmp/slide-1.png ]
Depending on how you did the require in settings.js you might need to do something like...
var PDFImage = global.get('pdf-image').PDFImage;
var pdfImage = new PDFImage(... Etc)
What does this show you?
node.warn(PDFImage)
Thanks for the reply Steve, the node.warn(PDFImage) throws no errors. So thats loading correctly. I also understand that I might be trying to use this package incorrectly as I have a buffer or Base64 that I want to convert and not necessarily provide a file location.
Require was done as follows:
functionGlobalContext: {
PDFImage:require('pdf-image')
Ok, but do you see an object in the debug output containing .PDFImage?
As for using it with a buffer or base64 string, check the repo or ask in the issues.
No object no, it only says "undefined"
Then I don't think it is loading.
What version of node-red are you running?
Currently running Node-red v1.3.4
Brilliant thanks. I implemented the functionexternalmodules feature and can see that it loads correctly now:
However when trying to use the function I still get the "TypeError: PDFImage is not a constructor" error. only code I have in my function node now is:
var pdfImage = new PDFImage(msg.payload);
Where msg.payload is a .pdf buffer. Also tried pointing to a pdf location as in the readme files but get the same error unfortunately
Try...
var pdfImage = new PDFImage.PDFImage(msg.payload);
... Do something with it / read the docs
