Hi all.
So I am really tired, or stupid. Please, help, if you have any idea.
Here is the code of flow, that read DB with IP and ID(ASDU) and after that use this data in cycle put to Modbus to read the data about temp, voltage and current from modbus devices.
So the increment in cycle does not running.
"id": "2e031c0d462c62b7",
"type": "tab",
"label": "Flow 1",
"disabled": false,
"info": "",
"env": []
"id": "358df04e372457f9",
"type": "debug",
"z": "2e031c0d462c62b7",
"name": "debug 201",
"active": true,
"tosidebar": true,
"console": true,
"tostatus": true,
"complete": "payload",
"targetType": "msg",
"statusVal": "payload",
"statusType": "auto",
"x": 740,
"y": 360,
"id": "8d2b804eec4f5ac3",
"type": "function",
"name": "file_read_name",
"func": "var msg1, msg2, msg3;\nvar arr = [];\nvar arr2 = [];\nvar j = 1, msg_sum = [];\nvar mpl = msg.payload.length;\n\nfor (var i = 0; i < mpl; i++) {\n //arr.push({ [msg.payload[i].location]: msg.payload[i].id });\n arr2.push(msg.payload[i].id + \";\" +msg.payload[i].location + \";\" + msg.payload[i].ris_ip + \";\" + msg.payload[i].ris_id); \n}\n \nmsg2 = { payload: arr2};\nmsg3 = { payload: mpl };\n\n return [msg1, msg2, msg3];\n",
"outputs": 3,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 160,
"y": 140,
"f2d5d1a5d34011ec",
"9ff5c4420360c041"
"62e130a6f418f15f",
"e4c7889d5cdf3499"
"id": "62e130a6f418f15f",
"type": "debug",
"name": "debug 202",
"active": true,
"tosidebar": true,
"console": true,
"tostatus": true,
"x": 460,
"y": 130,
"id": "be63f7ba6361208a",
"type": "inject",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "3",
"crontab": "",
"once": true,
"onceDelay": "2",
"topic": "",
"payload": "1",
"payloadType": "num",
"x": 130,
"y": 190,
"362add31d809355f"
"id": "e301e35a75e47053",
"type": "debug",
"name": "debug 203",
"active": true,
"tosidebar": true,
"console": true,
"tostatus": true,
"x": 500,
"y": 490,
"id": "95fbc3f6c0414b9e",
"type": "debug",
"name": "debug 204",
"active": true,
"tosidebar": true,
"console": true,
"tostatus": true,
"x": 720,
"y": 420,
"id": "79f70ee7fd767751",
"type": "inject",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "600",
"crontab": "",
"once": true,
"onceDelay": "1",
"topic": "SELECT * FROM ups_data ORDER BY id",
"payload": "",
"payloadType": "date",
"x": 140,
"y": 20,
"d87824dfc8fc26fb"
"id": "f2d5d1a5d34011ec",
"type": "debug",
"name": "debug 205",
"active": true,
"tosidebar": true,
"console": true,
"tostatus": true,
"x": 460,
"y": 70,
"id": "4700f489a8ea3b5b",
"type": "debug",
"name": "debug 206",
"active": true,
"tosidebar": true,
"console": true,
"tostatus": true,
"x": 710,
"y": 500,
"id": "46d2ac062aede649",
"type": "modbus-flex-connector",
"maxReconnectsPerMinute": 4,
"emptyQueue": false,
"showStatusActivities": true,
"showErrors": false,
"server": "8de5dabcee0a5816",
"x": 700,
"y": 240,
"9073bb7bff87b854"
"id": "9073bb7bff87b854",
"type": "debug",
"name": "debug 207",
"active": true,
"tosidebar": true,
"console": true,
"tostatus": true,
"x": 740,
"y": 300,
"id": "d87824dfc8fc26fb",
"type": "sqlite",
"mydb": "77663dac4f64af8e",
"sqlquery": "msg.topic",
"sql": "",
"name": "sqlitedb",
"x": 140,
"y": 80,
"8d2b804eec4f5ac3"
"id": "8bcf7aa79f19d4a4",
"type": "function",
"name": "function 21",
"func": "var msg1, msg2, msg3;\nvar sada_loc, sada_ip, sada_id, sada_rid;\nvar arr = [];\nvar arr2 = [], obsah = [] ;\nvar s = 0;\nobsah = flow.get(\"whole_string\");\nvar index = flow.get(\"records_sum\");\nvar incr = flow.get(\"increm\");\nvar select = flow.get(\"trigger_select\");\n\nif (select == 1) {\n \n var sada_def = obsah[incr].split(\";\");\n sada_rid = sada_def[0];\n sada_loc = sada_def[1];\n sada_ip = sada_def[2];\n sada_id = sada_def[3]; \n //msg3 = { payload: incr }; \n\nmsg1 = {\n payload: {\n 'connectorType': 'TCP',\n 'tcpHost': sada_ip,\n 'tcpPort': '502',\n 'unitId': sada_id\n }\n} \n if (incr >= 0) {\n s = incr;\n }\n if (s == index) {\n s = 0;;\n } else {\n s = s + 1;\n } \n msg2 = {payload: s}; \n return [msg1, msg2, msg3];\n}",
"outputs": 3,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 450,
"y": 320,
"46d2ac062aede649"
"95fbc3f6c0414b9e"
"4700f489a8ea3b5b"
"id": "9ff5c4420360c041",
"type": "change",
"rules": [
"t": "set",
"p": "whole_string",
"pt": "flow",
"to": "payload",
"tot": "msg",
"dc": true
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 440,
"y": 190,
"8bcf7aa79f19d4a4",
"358df04e372457f9"
"id": "e4c7889d5cdf3499",
"type": "change",
"rules": [
"t": "set",
"p": "records_sum",
"pt": "flow",
"to": "payload",
"tot": "msg",
"dc": true
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 430,
"y": 240,
"8bcf7aa79f19d4a4"
"id": "e77f3f4d0bf9862f",
"type": "change",
"rules": [
"t": "set",
"p": "trigger_select",
"pt": "flow",
"to": "payload",
"tot": "msg"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 190,
"y": 320,
"8bcf7aa79f19d4a4"
"id": "362add31d809355f",
"type": "trigger",
"op1": "1",
"op2": "0",
"op1type": "num",
"op2type": "num",
"duration": "500",
"extend": false,
"overrideDelay": false,
"units": "ms",
"reset": "",
"bytopic": "all",
"topic": "topic",
"outputs": 1,
"x": 180,
"y": 250,
"e77f3f4d0bf9862f"
"id": "e9295fec37bfdce6",
"type": "change",
"rules": [
"t": "set",
"p": "increm",
"pt": "flow",
"to": "payload",
"tot": "msg",
"dc": true
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 290,
"y": 430,
"36937936b8946297"
"id": "36937936b8946297",
"type": "delay",
"pauseType": "delay",
"timeout": "1",
"timeoutUnits": "seconds",
"rate": "1",
"nbRateUnits": "1",
"rateUnits": "second",
"randomFirst": "1",
"randomLast": "5",
"randomUnits": "seconds",
"drop": false,
"allowrate": false,
"outputs": 1,
"x": 470,
"y": 410,
"8bcf7aa79f19d4a4",
"e301e35a75e47053"
"id": "8de5dabcee0a5816",
"type": "modbus-client",
"clienttype": "tcp",
"bufferCommands": true,
"stateLogEnabled": false,
"queueLogEnabled": false,
"failureLogEnabled": true,
"tcpHost": "192.168.1.240",
"tcpPort": "502",
"tcpType": "DEFAULT",
"serialPort": "/dev/ttyUSB",
"serialType": "RTU-BUFFERD",
"serialBaudrate": "9600",
"serialDatabits": "8",
"serialStopbits": "1",
"serialParity": "none",
"serialConnectionDelay": "100",
"serialAsciiResponseStartDelimiter": "0x3A",
"unit_id": "",
"commandDelay": 1,
"clientTimeout": 1000,
"reconnectOnTimeout": true,
"reconnectTimeout": 500,
"parallelUnitIdsAllowed": true,
"showWarnings": true,
"showLogs": true
"id": "77663dac4f64af8e",
"type": "sqlitedb",
"db": "/home/pi/SmartUPS/db_data_ups.sqlite",
"mode": "RW"
Many thanks to your ideas.
