Hi Everyone,
I would like to use "write file" and "file copy" commands in /var/opt/codesys/PlcLogic/visu/ folder but I got permisson denied error measage.
How could I add permisson to Node-RED to edit files in var folder?
Hi Everyone,
You need to set write access to the folder in the settings file, and the path is kind of fixed to the node-red/public/.... folder.
But I could be wrong on the last point.
What does this command show?
ls -al /var/opt/codesys/PlcLogic/visu
That will show you the owner, group and permissions for the folder.
I use the following command to give permisson for pi user to /var/opt/codesys folder.
Now it seems to me it works.
But is it the correct way to solve this problem?
sudo chown -R raspberry /var/opt/codesys
It's not generally a good idea to change the ownership or permissions of Linux system files & directories.
It's not generally a good idea to write to system directories either.
Why do you want to do this?
However, if you must, probably a better way is to write files somewhere else and then use the exec node with sudo to move them.
sudo mv i_really_know_what_i_am_doing.txt /var/opt/codesys/PlcLogic/visu
