Persistent global context used in template node
Hallo,
This code works perfect in a template node (html) to retrieve cvMode as a global variable... in memory.
Now I installed contrib-persistent-global-context, and with a function node... global.set('cvMode', "ON", "file").
Set & Get work fine.
settings.js contextStorage is set:
contextStorage: {
default: "memoryOnly",
memoryOnly: { module: 'memory' },
file: { module: 'localfilesystem' }
7 Dec 09:17:27 - [info] Node-RED version: v3.1.0
7 Dec 09:17:27 - [info] Node.js version: v18.18.2
7 Dec 09:17:27 - [info] Linux 6.1.0-rpi6-rpi-v8 arm64 LE
How to change value="{{global.cvMode}}" to get the variable from "file" ?
I also tried function getDocGVF which is called by windows.onload as part of :
function getDocGVF() {
document.getElementById('cvMode').value = global.get('cvMode', "file");
Neither worked.
:frowning:
Pls your advise.
Thanks.
T
oops... the copy lost the code:
input type="text" id="cvMode" name="cvMode" value="{{global.cvMode}}"
In order to make code readable and usable it is necessary to surround your code with three backticks (also known as a left quote or backquote ```)
   code goes here
You can edit and correct your post by clicking the pencil :pencil2: icon.
From template node help text
t is possible to use a property from the flow context or global context. Just use {{flow.name}} or {{global.name}} , or for persistable store store use {{flow[store].name}} or {{global[store].name}} .
So {{global[file].cvMode}} should work
Thank You.
  1. I will comply the 3 backticks next time.
    2.Yes, the suggestion works perfect
  2. the template node help text... slipped my attention. Too much focussed on the syntax of set/get.
    Best Regards.
    T
All GlobalVariables work now fine in functions and can be used in html.
On RPi I can observe them landing in directory /home/rpi/.node-red/context/global/global.json.
But when I drag an Inject, the Persistent-Global-Context and a Debug node on a flow, then I get :
"Error: ENOENT: no such file or directory, open 'undefined/GlobalContext.json'"
and
"Cannot find json file inside [undefined/GlobalContext.json]!" from the Debug node
A Stop/Start of Node-Red does not show errors on the CommandLine of RPi.
What am I missing ?
Cheers,
T
I don't understand what you mean by that.
There is no need for that, persistent context is built into node-red core.
Thank You.
As there is no need... I removed it, and all works still fine.
As a NR novice I just tried to understand why
Cheers,
T
I tried it and get the same error. It appears to be a bug in the node. You could report an issue on the node's github page if you wanted to.
