PLEASE help - UI Form Data to SQLite db
HI, All you NR superstars!! I really need urgent help on a seems to be something simple that I of some reason just can't get to work after 3 days of trying, and a LOT of Reading !!!
I attempting to pass data from a UI Form from the dashboard into an SQLite dB.
Hardware: Raspberry PI 4 / Node-Red v 1.0.6
So far I have successfully
  • created Dashboard with the relevant form to add a " new user" called "users"
  • I have installed SQLite and have created the DB with the relevant table for the user as "users" ( Confirmed)
The Issue - I have tried to pass the [ Form ] data to a [ function ] node and link it to the [ SQLite ] node as per the instructions founded here on these forums.
Unfortunately, regardless of the millions of attemps in all different ways, forms, and methods, I just don't seem to get any values to the Sqlite node from the function node.
Can some PLEASE be so kind and inform me what I am doing wrong, I'm sure its something simple, I just don't seem to identify the issue.
here is my Function node code that's playing dead :
var users="user_name:Johnny,User_surname:Bravo,user_pin:3333,user_acc_level:1,user_acc_code:1";
//extract elements from data
var user_name=payload.user_name;
var user_surname=payload.User_surname;
var user_pin=payload.user_pin;
var user_acc_level=payload.user_acc_level;
var user_acc_code=payload.user_acc_code;
//create SQL command
msg="(user_name,User_surname,user_pin,user_acc_level,user_acc_code) values("+",\'"+user_name +"\',\'"+User_surname +"\'," + user_pin + "," + user_acc_level +"," + user_acc_code +")";
var topic="INSERT INTO USERS" +msg;
var msg1={}; //create new msg object
//The SQlite node expects the command in the topic field
msg1.topic=topic;
return msg1;
and this is the "debug" values ( complete msg object) from the incoming form data to the function node
ty7/3/2020, 4:33:49 PMnode: 8d87e409.564458
users : msg : Object
object
payload: object
user_name: "Jac"
User_surname: "McDonald"
user_pin: 9874
user_acc_level: 5
user_acc_code: 1
topic: "users"
socketid: "TbsdLj_kQzyESfbBAAAH"
_msgid: "d16e70ab.d3361"pe or paste code here
Your fast responses will be greatly appreciated to get this thing to work asap. thanks in advance !!
In a function node, you need to access payload via the msg object
E.g...
var user_pin=msg.payload.user_pin;
Ps, use a different variable name than msg for building your SQL
E.g...
var sql="(user_name,User_surname,user_pin,user_acc_level,user_acc_code) values("+",\'"+user_name +"\',\'"+User_surname +"\'," + user_pin + "," + user_acc_level +"," + user_acc_code +")";
var topic="INSERT INTO USERS" +sql;
msg.topic=topic;
HI Steve , thanks for your quick response
let me digest your replay quick, please dont go away...ahahh
So , if i understood you correctly , if i swap out the "var msg" before the sql command , then it should work ?
no worries - here is another tip...
use template strings to improve readability...
var mystr = `this is a template string and this is the value of a variable - ${myVariable}`
so your SQL would be...
msg.topic = `INSERT INTO USERS (
  user_name, User_surname, user_pin, user_acc_level, user_acc_code
) values (
   '${user_name}', '${User_surname}', '${user_pin}', ${user_acc_level}, ${user_acc_code}
no
try this...
//get values from msg...
var user_name= msg.payload.user_name;
var user_surname= msg.payload.User_surname;
var user_pin= msg.payload.user_pin;
var user_acc_level= msg.payload.user_acc_level;
var user_acc_code= msg.payload.user_acc_code;
) values (
   '${user_name}', '${user_surname}', '${user_pin}', ${user_acc_level}, ${user_acc_code}
hey Steve, I have tried the "SQL Command with "var sql" as instructed and , still no response from the function node to the SQL node ..
msg.topic=topic;
try this...
node.warn([user_name, user_surname, user_pin, user_acc_level, user_acc_code])
) values (
node.warn(msg.topic);
show me what appears in your debug panel.
Hey Steve, Your the BOSS, Thanks so much !! it worked. my inexperience in SQL is embarrassing, but thankfully there are the superstars like STEVE-Mcl !! thank you again and again !!
here is the results from the debug
7/3/2020, 5:47:42 PMnode: e6eb54ae.445558
INSERT INTO USERS ( user_name, User_surname, user_pin, user_acc_level, user_acc_code ) values ( 'Jac', 'McDonald', '9874', 5, 1 ); : msg : Object
object
payload: array[0]
topic: string
INSERT INTO USERS (
) values (
_msgid: "a3e3080c.269d28"
and confirmed in the DB table :
SELECT * FROM USERS : msg.payload : array[2]
array[2]
0: object
user_name: "Pieter"
user_surname: "Hover"
User_pin: 5054
user_acc_level: 5
user_acc_code: 1
1: object
user_name: "Jac"
user_surname: "McDonald"
User_pin: 9874
user_acc_level: 5
user_acc_code: 1
No worries, glad to help.
PS, dont forget to mark the thread as complete :+1:
EDIT - you beat me to it :slight_smile:
will do , have a awesome day / night ...ps i might to puch on your bt soon again ( tonight)
