Post data to influxdb 1.x with own timestamp
I need to post data to InfluxDB with its original timestamp since the data may arrive at the database at a different time from when it was generated. I'm encountering difficulties!
The influx version is still the 1.x
This is the typical payload I receive:
payload: "113|25.75|2023-09-07T06:32:28.434Z"
The last portion is the timestamp at the time the measurements taken.
This is the output of the function receiving the above payload:
This is the function I wrote:
if (msg.topic === "BMS!2022/temperature") {
    var t = msg.payload;
    // Find the last occurrence of a pipe, which should be the start of the timestamp
    var lastPipeIndex = t.lastIndexOf('|');
    // Extract DeviceID and temperature
    var DeviceID = t.substring(0, t.indexOf('|'));
    var Tamb = parseFloat(t.substring(t.indexOf('|') + 1, lastPipeIndex));
    // Extract the RFC 3339 timestamp
    var rfc3339Timestamp = t.substring(lastPipeIndex + 1);
    // Convert RFC 3339 timestamp to nanoseconds
    var date = new Date(rfc3339Timestamp);
    var nanoTimestamp = date.getTime() * 1e6;  // Convert milliseconds to nanoseconds
    msg.topic = "temperature";
    if (DeviceID && !isNaN(Tamb)) {
        msg.payload = {
            "Tamb": Tamb,
            "timestamp": nanoTimestamp  // Use nanosecond precision timestamp
        msg.measurement = DeviceID;
        msg.timestamp = nanoTimestamp;
} else {
    return null;
and this is the content of the measurement in influx:
time                Tamb   timestamp
1694064087553806889 22.312 1694064087550000000
1694064117590312070 22.312 1694064117586000000
1694064147639415844 22.312 1694064147614000000
based on what I see in the above influx output, the db is still using its own time stamp rather then the one I provide. This is also confirmed by showing the data on a chart.
I need some help to make sure that influx use the provided timestamp instead of the own one.
Try making it time in the payload instead of timestamp.
Hi Colin. You are a star! Thanks a million. It works well now.
