Power flow card - again
Again a reopen of power card topic- see(Energy flow widget)
Here my implementation based on the work of some people of this forum: Thanks a lot! :slightly_smiling_face:
flows(84).json (40.3 KB)
Bildschirmfoto vom 2024-04-06 22-40-40
Bildschirmfoto vom 2024-04-06 23-27-38
I use the animated energy card in HA, and I'm delighted to have just discovered this portage in NR.
It would be possible to document a little more the inputs expected by the various nodes of your flow.
This way, you could find the standardized entities from HA and then use them in your flow to animate the Power flow card.
In any case, it's very nice of you to share your work.
2024-04-07_20h27_37
Keep in mind that not everybody is using home assistant (most on this forum don't).
Thanks, was a bit trail and error to find out what was what but figured it out eventually :slight_smile:
Hello WP-Rue. Thanks for your Work. Maybe there is already an update or an improvement?
Indeed I have worked further on this project and have little improvements.. I can upload tomorrow…but the main goal was to show a possibility for realisation of a power flow card in node red…
One disadvantage of this widget seems to be the usage of a lot of cpu-power: Raspi4 with touch display and chrome running uses +35% for showing this widget. Any idea why?
flows-2.json (17.2 KB)
Power of some lines added. One bug was in the first version at the end of the function: the speed of the green line (wallbox) was calculated to a redline value. Fixed in the here uploaded version.
My opinion to this flow: you have to understand it and adapt it to your own home energy flows. It should work as an template to adapt to your own requirements...
Hi, I came across your flow by chance and think it's fantastic. I understand parts of it, too. But unfortunately, I'm having trouble with the inverter data. I've successfully connected a Sungrow SH15T via Modbus. However, I'm having trouble linking the registers. Now my question is: What kind of inverter are you using here, and can someone help me with register selection?
Hi Markus!
The inverter I use is a Victron Multiplus 2- but this flow is not related to any specific model of inverter..
For your Sungrow it would be better to create an extra issue with your specific question- maybe have a look at the forum from accu doctor- if german is ok…
Greetings Rue
