The power here fails fairly often. Not every day or even every week but probably every three weeks or so. Sometimes I'm not home so I got curious as to when the power failed and when it came back on. Nothing earth shattering but I wanted to "log" these outages for my own information. I designed a flow to note when the power failed by getting the time every minute and writing to context. Then when power comes on I note the time and subtract the two. I don't need split second timing so this seemed like a reasonable method. The problem is when the power comes back on sometimes I get negative duration numbers. Again sometimes....
I have been over my code and my methodology and I see nothing wrong with either. If someone has a better method I'm all for that but although this isn't life critical I'm now bound and determined to either fix my flow or find a way that does work consistently.
[{"id":"8c2a3f8f.ef9d8","type":"tab","label":"Power Fail","disabled":false,"info":""},{"id":"4861c45c.b4c5ac","type":"ui_template","z":"8c2a3f8f.ef9d8","group":"78f5f4b2.0d39f4","name":"power off duration","order":4,"width":0,"height":0,"format":"<div>\n<md-button class=\"md-button mine-button\"\n data-payload>{{msg.payload}}\n</md-button>\n</div>","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":true,"templateScope":"local","x":910,"y":360,"wires":[[]]},{"id":"6a70b25f.c5427c","type":"ui_template","z":"8c2a3f8f.ef9d8","group":"78f5f4b2.0d39f4","name":"power on time","order":2,"width":0,"height":0,"format":"<div>\n <md-button class=\"md-button mine-button\"\n data-topic=\"target\"\n data-payload=\"1\">{{msg.payload}}\n </md-button>\n</div>","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":true,"templateScope":"local","x":900,"y":320,"wires":[[]]},{"id":"6e54f4cc.bc10f4","type":"ui_template","z":"8c2a3f8f.ef9d8","group":"78f5f4b2.0d39f4","name":"power on header","order":1,"width":0,"height":0,"format":"\n<div>\n <md-button class=\"md-button mine-button\"\n data-topic=\"target\"\n data-payload=\"1\">Power On Time\n </md-button>\n</div>","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":true,"templateScope":"local","x":370,"y":140,"wires":[[]]},{"id":"33c7c87c.f84a28","type":"ui_template","z":"8c2a3f8f.ef9d8","group":"78f5f4b2.0d39f4","name":"Duration of power off header","order":3,"width":0,"height":0,"format":"\n<div>\n <md-button class=\"md-button mine-button\"\n data-topic=\"target\"\n data-payload=\"1\">Power Off Duration\n </md-button>\n</div>","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":true,"templateScope":"local","x":680,"y":140,"wires":[[]]},{"id":"1290440ad0071cae","type":"function","z":"8c2a3f8f.ef9d8","name":"display","func":"let z = flow.get('powerOnTime');\n\nlet y = flow.get('durationTime');\n\nmsga = {\n payload: z,\n}\n\nmsgb = {\n payload: y,\n}\n\nnode.status({fill:\"blue\",shape:\"dot\",text:\"duration\" + y});\n\nreturn [msga,msgb];","outputs":2,"noerr":0,"initialize":"","finalize":"","libs":[],"x":640,"y":340,"wires":[["6a70b25f.c5427c"],["4861c45c.b4c5ac"]]},{"id":"4f71468e6af2473c","type":"function","z":"8c2a3f8f.ef9d8","name":"open gate","func":"msg = {\n topic: 'control',\n payload: 'open'\n}\n\nnode.status({fill:\"blue\",shape:\"dot\",text:msg.payload});\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":930,"y":500,"wires":[["6d9cd422f6eb8d66"]]},{"id":"6d9cd422f6eb8d66","type":"gate","z":"8c2a3f8f.ef9d8","name":"gate 2","controlTopic":"control","defaultState":"closed","openCmd":"open","closeCmd":"close","toggleCmd":"toggle","defaultCmd":"default","statusCmd":"status","persist":false,"storeName":"default","x":250,"y":340,"wires":[["da8fa542bc9a4a1b"]]},{"id":"e0fe68ba037f8422","type":"link in","z":"8c2a3f8f.ef9d8","name":"power fail power on in","links":["88f921a718be8937"],"x":135,"y":500,"wires":[["1328d2d51c18057b","53ff67ac3914f31d"]]},{"id":"d3d8ea7e47a9bff4","type":"link in","z":"8c2a3f8f.ef9d8","name":"pwr fail minute in","links":["73a9a142252c1869"],"x":135,"y":340,"wires":[["6d9cd422f6eb8d66"]]},{"id":"2768838c8954f069","type":"moment","z":"8c2a3f8f.ef9d8","name":"pwr on","topic":"topic","input":"payload","inputType":"msg","inTz":"America/Devver","adjAmount":0,"adjType":"days","adjDir":"add","format":"ddd MMM DD YYYY H:mm:ss","locale":"en-US","output":"","outputType":"msg","outTz":"America/Denver","x":550,"y":500,"wires":[["abb7e70be6844e3b"]]},{"id":"1328d2d51c18057b","type":"function","z":"8c2a3f8f.ef9d8","name":"pwr on date/time","func":"var d = new Date();\nvar n = d.getTime();\n\nmsg = {\n payload: n,\n topic: 'epoch'\n}\n\nflow.set('powerOn',msg.payload);\n\nnode.status({fill:\"blue\",shape:\"dot\",text:msg.payload});\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":370,"y":500,"wires":[["2768838c8954f069"]]},{"id":"abb7e70be6844e3b","type":"function","z":"8c2a3f8f.ef9d8","name":"flow pwr on","func":"flow.set('powerOnTime',msg.payload);\n\nnode.status({fill:\"blue\",shape:\"dot\",text:msg.payload});\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":730,"y":500,"wires":[["4f71468e6af2473c"]]},{"id":"da8fa542bc9a4a1b","type":"function","z":"8c2a3f8f.ef9d8","name":"set pwr off","func":"var d = new Date();\nvar n = d.getTime();\n\nmsg = {\n payload: n,\n topic: 'epoch'\n}\n\n\nflow.set('powerOff',msg.payload);\n\nnode.status({fill:\"blue\",shape:\"dot\",text:msg.payload});\n\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":410,"y":340,"wires":[["1290440ad0071cae","d7707b5dfbd8728d"]]},{"id":"d7707b5dfbd8728d","type":"moment","z":"8c2a3f8f.ef9d8","name":"pwr off date/time","topic":"","input":"payload","inputType":"msg","inTz":"America/Denver","adjAmount":0,"adjType":"days","adjDir":"add","format":"ddd MMM DD YYYY H:mm:ss","locale":"en-US","output":"payload","outputType":"msg","outTz":"America/Denver","x":610,"y":240,"wires":[["0ad26863b208a127"]]},{"id":"0ad26863b208a127","type":"function","z":"8c2a3f8f.ef9d8","name":"english pwr off","func":"flow.set('powerOffTime',msg.payload);\n\nnode.status({fill:\"blue\",shape:\"dot\",text:msg.payload});\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":840,"y":240,"wires":[[]]},{"id":"53ff67ac3914f31d","type":"function","z":"8c2a3f8f.ef9d8","name":"duration seconds","func":"\nlet z = flow.get('powerOn');\n\nlet y = flow.get('powerOff');\n\nlet w = z - y;\n\nlet x = (w / 1000); //seconds\n\nflow.set('duration',x);\n\nnode.status({fill:\"blue\",shape:\"dot\",text:x});\n\nreturn msg;\n","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":370,"y":580,"wires":[["5cd5862a86d0ce5a"]]},{"id":"5cd5862a86d0ce5a","type":"function","z":"8c2a3f8f.ef9d8","name":"duration time","func":"\nlet z = flow.get('duration');\n\nlet v =secondsToHms(z);\n\nfunction secondsToHms(d) {\n d = Number(d);\n var h = Math.floor(d / 3600);\n var m = Math.floor(d % 3600 / 60);\n var s = Math.floor(d % 3600 % 60);\n\n var hDisplay = h > 0 ? h + (h == 1 ? \" hr, \" : \" hrs, \") : \"\";\n var mDisplay = m > 0 ? m + (m == 1 ? \" min, \" : \" mins, \") : \"\";\n var sDisplay = s > 0 ? s + (s == 1 ? \" sec\" : \" secs\") : \"\";\n return hDisplay + mDisplay + sDisplay; \n}\n\nflow.set('durationTime',v);\n\nnode.status({fill:\"blue\",shape:\"dot\",text:v});\n\nreturn null;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":630,"y":580,"wires":[[]]},{"id":"ee5b8013115e178b","type":"inject","z":"8c2a3f8f.ef9d8","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"1","payloadType":"num","x":130,"y":580,"wires":[["1328d2d51c18057b","53ff67ac3914f31d"]]},{"id":"300ae3cfa4d6de3e","type":"inject","z":"8c2a3f8f.ef9d8","name":"close","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"1","payloadType":"num","x":90,"y":220,"wires":[["3842d51ff46668ce"]]},{"id":"3842d51ff46668ce","type":"function","z":"8c2a3f8f.ef9d8","name":"","func":"msg = {\n topic: 'control',\n payload: 'close'\n}\n\nnode.status({ fill: \"blue\", shape: \"dot\", text: msg.payload });\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":270,"y":220,"wires":[["6d9cd422f6eb8d66"]]},{"id":"9c27943a82e3abaf","type":"comment","z":"8c2a3f8f.ef9d8","name":"fires every minute","info":"","x":150,"y":300,"wires":[]},{"id":"5136f83e29ba33de","type":"comment","z":"8c2a3f8f.ef9d8","name":"fires at power on","info":"","x":140,"y":460,"wires":[]},{"id":"78f5f4b2.0d39f4","type":"ui_group","name":"Power","tab":"f31d1a37.01d2","order":1,"disp":false,"width":"6","collapse":false},{"id":"f31d1a37.01d2","type":"ui_tab","name":"Power","icon":"fa-power-off","order":12,"disabled":false,"hidden":false}]
Note: one non core node node-red-contrib-simple-gate
Any input appreciated.
