All,
It appears that preceding spaces or trailing spaces are ignored in a text input.
This becomes an issue when we do a 'password entry'
There is also no trigger on the output when a space is entered.
Example code
[{"id":"de2de0af.b6406","type":"ui_text_input","z":"37e2c67c.85274a","name":"","label":"","tooltip":"","group":"668d9db5.aab0e4","order":2,"width":0,"height":0,"passthru":true,"mode":"text","delay":"100","topic":"","x":340,"y":280,"wires":[["17f4886.d747c78"]]},{"id":"9dbeea4a.9fd778","type":"ui_text_input","z":"37e2c67c.85274a","name":"","label":"","tooltip":"","group":"668d9db5.aab0e4","order":1,"width":0,"height":0,"passthru":true,"mode":"password","delay":"100","topic":"","x":360,"y":330,"wires":[["e86ed49d.f07ec8"]]},{"id":"17f4886.d747c78","type":"debug","z":"37e2c67c.85274a","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":640,"y":280,"wires":[]},{"id":"e86ed49d.f07ec8","type":"debug","z":"37e2c67c.85274a","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":640,"y":330,"wires":[]},{"id":"668d9db5.aab0e4","type":"ui_group","name":"Group 1","tab":"1cec7880.5a4688","order":1,"disp":true,"width":6},{"id":"1cec7880.5a4688","type":"ui_tab","z":"","name":"Example entry","icon":"dashboard","order":7,"disabled":false,"hidden":false}]
As you can see in above example, we entered the following
'   3 spaces   ' (Not the '')
But the payload out of the function is in both cases
{"payload":"3 spaces","socketid":"XrYwAW7CPErPnN2WAAAJ","_msgid":"434e6646.6207c8"}
any spaces between characters are captured.
This causes me grief as I use the password entry and compare this with a fixed entry.
The user thinks he entered 14 characters, but the payload only presents 8 characters.
If the entry is made only out of spaces, then no payload is delivered out of the text input function
Any way to get around this?
 ... but seriously, if the input is trimming whitespace by default, it does feel like there should be an option to not do that. It isn't for us to decide what is valid input or not.
