How to insert blank text space in a UI text node?
Hi all,
Do you know how to insert "blank text" in this line?
I tried spaces (keyboard space bar), but they don't count. I have to put characters (points) to separate these 2 values.
{{payload.temp}}°c ..... <span class="fa fa-tint"></span>{{payload.hum}} %<br> <span class="fa fa-signal"></span><small>{{payload.rxRSSI}} dB</small>
How to replace "points " to "blank text space " ?
Try &nbsp;&nbsp;&nbsp;&nbsp;
Or
<pre>       </pre>
result of : <pre> </pre> looks like <br>
result of : &nbsp;&nbsp;&nbsp;&nbsp;
Wonderfull ! it's working !
Thanks @E1cid
Put the temps inside the <pre></pre>
temp1      temp2
sorry i think i don't understand (i'm beginner in html ):
like this : <pre>temp1 temp2</pre> ?
[EDIT] Howw ! i understand i have to put my payloads inside
 ! okk !
the result :
<pre>{{payload.temp}}°c    <span class="fa fa-tint"></span>{{payload.hum}} %</pre><br> <span class="fa fa-signal"></span><small>{{payload.rxRSSI}} dB</small>
:thinking: there is a strange reaction :
after the "%" there is a <br> and the line break is huge, and the font has changed.
So i think i keep &nbsp; solution :slight_smile:
Just for info.
<pre>{{payload.temp}}°c    <span class="fa fa-tint"></span>{{payload.hum}} %<br> <span class="fa fa-signal"></span><small>{{payload.rxRSSI}} dB</small></pre>
As the pre would add a line break.
ah yes, exact if I remove the <br> I am less "discarded".
I learned a lot of things, it's cool. Thanks
In addition or instead, you can use &ensp; or &emsp; or &thinsp; to give a bit more exact control of the spacing.
Thanks for this add , it's usefull too :
