I've got an issue and I'm wondering if there is a simple solution
My real flow makes a Pi speak to an Alexa echo so ends converting text to an mp3
For monitoring / debugging purposes I want to keep the original text bound in same message as the mp3.
I'm using flow context to remember original text and then re-add it back in later on after mp3 produced but I've realised that if another message comes in before the processing is finished - the wrong text is re-added to the message downstream
Here is a simple example of the situation forcing two messages in quick sucession - please assume the group wipes any properties other than msg.payload - if it didn't - then I wouldn't have this problem
[{"id":"075cafcf3e03a909","type":"inject","z":"04a1000c0394426c","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":120,"y":100,"wires":[["306c1dcd9894fb34","87e28ae8d7e42d44"]]},{"id":"306c1dcd9894fb34","type":"change","z":"04a1000c0394426c","name":"payload =\"1\"","rules":[{"t":"set","p":"payload","pt":"msg","to":"1","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":290,"y":80,"wires":[["199a427ce735b3c3"]]},{"id":"87e28ae8d7e42d44","type":"change","z":"04a1000c0394426c","name":"payload = \"2\"","rules":[{"t":"set","p":"payload","pt":"msg","to":"2","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":290,"y":120,"wires":[["199a427ce735b3c3"]]},{"id":"c27301eff0ed2c7d","type":"debug","z":"04a1000c0394426c","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":1270,"y":100,"wires":[]},{"id":"199a427ce735b3c3","type":"change","z":"04a1000c0394426c","name":"","rules":[{"t":"set","p":"originalPayload","pt":"flow","to":"payload","tot":"msg","dc":true}],"action":"","property":"","from":"","to":"","reg":false,"x":490,"y":100,"wires":[["81097fec7cc38aa4"]]},{"id":"54c596ca1200e345","type":"change","z":"04a1000c0394426c","name":"","rules":[{"t":"set","p":"originalPayload","pt":"msg","to":"originalPayload","tot":"flow","dc":true}],"action":"","property":"","from":"","to":"","reg":false,"x":1090,"y":100,"wires":[["c27301eff0ed2c7d"]]},{"id":"58a2fd211ccbf25a","type":"group","z":"04a1000c0394426c","name":"Dummy operation - assume that it only passes\\n msg.payload and takes a bit of time","style":{"label":true},"nodes":["81097fec7cc38aa4","cdafe5f730292e07"],"x":594,"y":43,"w":392,"h":98},{"id":"81097fec7cc38aa4","type":"delay","z":"04a1000c0394426c","g":"58a2fd211ccbf25a","name":"","pauseType":"delay","timeout":"2","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":680,"y":100,"wires":[["cdafe5f730292e07"]]},{"id":"cdafe5f730292e07","type":"change","z":"04a1000c0394426c","g":"58a2fd211ccbf25a","name":"","rules":[{"t":"change","p":"payload","pt":"msg","from":"","fromt":"str","to":" changed ","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":860,"y":100,"wires":[["54c596ca1200e345"]]}]
