Hi. Your image is not great quality. Can you post the logs as text?
Additionally, you pasted the function code without putting it inside of a code block (see canned info below). I've tried editing your post but your function code is pretty much messed up due to not having it in a code block in the first place. Can you correct that?
Next, can you tell us what type of PLC make & model?
Other information that may be useful would be the node.js version you're running on?
canned info
code goes here
icon.
