I have a working flow reading values from a PLC using OPC UA.
The debug node returns the correct value but is followed by an error message "Client node error on: PLC"
Any ideas why this error is there?
9/23/2020, 12:32:27 PMnode: PLCmsg : string[25]
9/23/2020, 12:32:27 PMnode: 354de427.6cfe8cns=4;s=Arp.Plc.Eclr/Curing1_Humidity : msg : Object
object
_msgid: "8a9a6674.888bd8"
topic: "ns=4;s=Arp.Plc.Eclr/Curing1_Humidity"
datatype: "Real"
payload: 65.76667022705078
statusCode: object
[{"id":"a76730ee.dd86e","type":"inject","z":"cbd7a6f3.2501a8","name":"Curing1_Humidity","props":[{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"ns=4;s=Arp.Plc.Eclr/Curing1_Humidity;datatype=Real","payloadType":"str","x":690,"y":200,"wires":[["29b65a21.548346"]]},{"id":"29b65a21.548346","type":"OpcUa-Client","z":"cbd7a6f3.2501a8","endpoint":"2dc95988.0b8d76","action":"read","deadbandtype":"a","deadbandvalue":1,"time":10,"timeUnit":"s","certificate":"n","localfile":"","securitymode":"None","securitypolicy":"None","name":"PLC","x":890,"y":200,"wires":[["ac3b13e9.1af5d","354de427.6cfe8c"]]},{"id":"7dc9bdab.a6fcb4","type":"debug","z":"cbd7a6f3.2501a8","name":"","active":false,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":1190,"y":200,"wires":[]},{"id":"ac3b13e9.1af5d","type":"function","z":"cbd7a6f3.2501a8","name":"Fix decimal","func":"msg.payload = parseFloat(msg.payload.toFixed(1))\nreturn msg;\n","outputs":1,"noerr":0,"initialize":"","finalize":"","x":1030,"y":200,"wires":[["7dc9bdab.a6fcb4"]]},{"id":"354de427.6cfe8c","type":"debug","z":"cbd7a6f3.2501a8","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":1060,"y":260,"wires":[]},{"id":"2dc95988.0b8d76","type":"OpcUa-Endpoint","z":"","endpoint":"opc.tcp://10.0.0.99:4840","secpol":"None","secmode":"NONE","login":false}]
