"aplay somefile.wav" with or without -D default works fine om my raspberry to play audio to paired bluetooth speaker.
The same command from within exec node gives error: "aplay: main830: audio open error: unknown error 524"
Other commands issued using exec node work fine.
I controll the moving parts of my christmas village this way but no music ...
Thanks Cymplecy,
I looked at your suggestion. Aplay should play via bluetooth. It does when invoked in a terminal session so I think this is the default now. Using "aplay -D default file.wav" using node red exec however gives the error. Tried other options then "default". "-D pulse" works from terminal. From nore red exec it gives an other error:
ALSA lib pulse.c:242:(pulse_connect) PulseAudio: Unable to connect: Connection refused
aplay: main:830: audio open error: Connection refused
using "paplay file.wav" from exec node results in "Connection failure: Connection refused
pa_context_connect() failed: Connection refused"
How are you running node-red? If running it as a service try stopping it (node-red-stop) and run it directly in the terminal using node-red
If it plays now then possibly the node-red user is not in the audio group.
Hi Colin,
I start node red as a service, but i have to login opening the web interface. Node red exec node "whoami" returns my username, so i think (p)aplay is called as me?
Hi Colin,
I thought i did without result, now for second time is does work.
I see no user node-red in /etc/passwd? how to add it to group audio then?
added myself to pulse and pulse-access. don't know is that was smart...
What is my next step?
Thanks so far!
Look in the systemd service to see what is the user running the service cat /lib/systemd/system/nodered.service
There should be lines near the start setting the User and Group.
So is that the same user that you were logged in as when you ran node-red. If so then it is not the group, it must be something to do with the environment when logged in via ssh versus the service running.
When using a headless rpi running Bullseye to get aplay to work through an Exec node for Bluetooth speakers I had to make PulseAudio specifically available to Node Red. Have a look at the section of my notes PdeJ - Connect to Bluetooth
A combination of the suggestions of PdJ and Colin seems to work. after rebooting the pizero i now issue "node-red-stop" and "node-red &". then "bluetoothctl power on" and "bluetoothctl connect mac-addres-speaker".
Then the exec node "aplay -D pulse somevfile.wav" works.
Okay for now. Would like a solution whitout manualy restarting node-red in the future. probably start node red not as a service but from login script of user?
With my lack of experience I need a bit more guidance.
could you give me another nudge please?
sudo systemctl status nodered just after boot is:
yede@pizero1:~ $ sudo systemctl status nodered
Failed to get journal cutoff time: Bad message
● nodered.service - Node-RED graphical event wiring tool
Loaded: loaded (/lib/systemd/system/nodered.service; enabled; vendor preset: enabled)
Active: active (running) since Fri 2023-12-15 10:12:17 CET; 1min 31s ago
Docs: http://nodered.org/docs/hardware/raspberrypi.html
Main PID: 247 (node)
Tasks: 11 (limit: 414)
CPU: 33.011s
CGroup: /system.slice/nodered.service
└─247 node --max_old_space_size=256 /usr/lib/node_modules/node-red/bin/../red.js
Dec 15 10:12:17 pizero1 systemd[1]: Started Node-RED graphical event wiring tool.
Dec 15 10:12:52 pizero1 Node-RED[247]: 15 Dec 10:12:52 - [info]
Dec 15 10:12:52 pizero1 Node-RED[247]: Welcome to Node-RED
Dec 15 10:12:52 pizero1 Node-RED[247]: ===================
Dec 15 10:12:53 pizero1 Node-RED[247]: 15 Dec 10:12:52 - [info] Node-RED version: v3.1.0
Dec 15 10:12:53 pizero1 Node-RED[247]: 15 Dec 10:12:52 - [info] Node.js version: v18.17.1
Dec 15 10:12:53 pizero1 Node-RED[247]: 15 Dec 10:12:52 - [info] Linux 6.1.21+ arm LE
Dec 15 10:13:29 pizero1 Node-RED[247]: 15 Dec 10:13:29 - [info] Loading palette nodes
Dec 15 10:13:50 pizero1 Node-RED[247]: 15 Dec 10:13:50 - [info] Dashboard version 3.6.2 started at /ui
yede@pizero1:~ $ node-red-stop
after stopping and starting like you told me it is:
Active: inactive (dead) since Fri 2023-12-15 10:33:24 CET; 3h 41min ago
Process: 247 ExecStart=/usr/bin/env node-red-pi $NODE_OPTIONS $NODE_RED_OPTIONS (code=exited, status=0/SUCCESS)
Main PID: 247 (code=exited, status=0/SUCCESS)
CPU: 51.453s
Dec 15 10:13:57 pizero1 Node-RED[247]: 15 Dec 10:13:57 - [info] Starting flows
Dec 15 10:13:59 pizero1 Node-RED[247]: 15 Dec 10:13:59 - [info] Started flows
Dec 15 10:13:59 pizero1 Node-RED[247]: 15 Dec 10:13:59 - [info] [mqtt-broker:9ef57e0297253107] Connected to broker: mqtt://localhost:1883
Dec 15 10:33:24 pizero1 systemd[1]: Stopping Node-RED graphical event wiring tool...
Dec 15 10:33:24 pizero1 Node-RED[247]: 15 Dec 10:33:24 - [info] Stopping flows
Dec 15 10:33:24 pizero1 Node-RED[247]: 15 Dec 10:33:24 - [info] [mqtt-broker:9ef57e0297253107] Disconnected from broker: mqtt://localhost:1883
Dec 15 10:33:24 pizero1 Node-RED[247]: 15 Dec 10:33:24 - [info] Stopped flows
Dec 15 10:33:24 pizero1 systemd[1]: nodered.service: Succeeded.
Dec 15 10:33:24 pizero1 systemd[1]: Stopped Node-RED graphical event wiring tool.
Dec 15 10:33:24 pizero1 systemd[1]: nodered.service: Consumed 51.453s CPU time.
/lib/systemd/system/nodered.service is:
# systemd service file to start Node-RED
[Unit]
Description=Node-RED graphical event wiring tool
Wants=network.target
Documentation=http://nodered.org/docs/hardware/raspberrypi.html
[Service]
Type=simple
# Run as normal pi user - change to the user name you wish to run Node-RED as
User=yede
Group=yede
WorkingDirectory=/home/yede
Environment="NODE_OPTIONS=--max_old_space_size=256"
# define an optional environment file in Node-RED's user directory to set custom variables externally
EnvironmentFile=-/home/yede/.node-red/EnvironmentFile
# uncomment and edit next line if you need an http proxy
#Environment="HTTP_PROXY=my.httpproxy.server.address"
# uncomment the next line for a more verbose log output
#Environment="NODE_RED_OPTIONS=-v"
# uncomment next line if you need to wait for time sync before starting
#ExecStartPre=/bin/bash -c '/bin/journalctl -b -u systemd-timesyncd | /bin/grep -q "systemd-timesyncd.* Synchronized to time server"'
#ExecStart=/usr/bin/env node $NODE_OPTIONS red.js $NODE_RED_OPTIONS
# Use SIGINT to stop
KillSignal=SIGINT
# Auto restart on crash
Restart=on-failure
RestartSec=20
# Tag things in the log
SyslogIdentifier=Node-RED
#StandardOutput=syslog
[Install]
WantedBy=multi-user.target
Actually there may be an easier way. What happens if you run an exec node containing bluetoothctl power on ; bluetoothctl connect mac-addres-speaker
before your aplay exec node?
Sorry for late reaction. Busy period of the year.
I issue both commands. Manuallly when testing, or as part of the script that runs my music, steppermotors and servo's.
For now I can live with the current situation: restart node-red manually after booting the pizero and don't switch it off until next year.
happy hollidays.
Yede
