Problem to var require = global.get('require'); - 3 scheet to 1 xlsx
Want to use 3 queries and feed 3 sheets in excel all the time I have an error
I corrected in settings file
Nothing helped
or maybe some quick solution what to change in code ?
        "id": "184a71d3.6af50e",
        "type": "function",
        "z": "47d8dd38b03906ea",
        "func": "\nmsg.attachments= [\n        {   \n            filename: msg.filename,\n            content: msg.excel,\n            encoding: 'base64'\n        }\n        ]\n\n// if (msg.ZalaczRaportDoTresci === true)\n// {\n//     msg.body = msg.payload;\n// }\n// else \n// {\n//     msg.body = msg.wiadomosc;\n// }\n\nmsg.before= msg.wiadomosc;\n\n\nreturn msg;\n",
        "outputs": 1,
        "noerr": 0,
        "x": 1065,
        "y": 180,
        "l": false
        "id": "33bd0017.24fa4",
        "type": "tableify",
        "before": "",
        "after": "",
        "tableStyle": "",
        "theadStyle": "",
        "tbodyStyle": "",
        "trStyle": "",
        "tdStyle": "",
        "x": 1005,
        "y": 180,
                "184a71d3.6af50e"
        "l": false
        "id": "2206a863.9f2928",
        "type": "function",
        "name": "config",
        "func": "msg.to = msg.mail[0].email;\nmsg.cc = 'test@test.com';\n\n\nmsg.topic='Test join xlsx to scheet nr:'  ;\nmsg.filename = 'Test.xlsx';\n\nmsg.wiadomosc = 'Test Raports';  \nmsg.scheet1 = 'scheet1';\nmsg.scheet2 = 'scheet2';\nmsg.scheet3 = 'scheet3';\n\nmsg.before= \n\n`\nTest Raports\n\n\n`\n\n \n\n\nreturn msg;",
        "outputs": 1,
        "timeout": "",
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 780,
        "y": 180,
                "2515b35f.ff580c"
        "id": "7549c41c.03690c",
        "type": "function",
        "func": "msg.tableStyle=`{\n  border: 1px solid #1C6EA4;\n  background-color: #EEEEEE;\n  width: 100%;\n  text-align: left;\n  border-collapse: collapse;\n}`\n\nmsg.theadStyle=` background: #1C6EA4;\n  background: -moz-linear-gradient(top, #5592bb 0%, #327cad 66%, #1C6EA4 100%);\n  background: -webkit-linear-gradient(top, #5592bb 0%, #327cad 66%, #1C6EA4 100%);\n  background: linear-gradient(to bottom, #5592bb 0%, #327cad 66%, #1C6EA4 100%);\n  border-bottom: 2px solid #444444;`;\n\nmsg.tbodyStyle=`font-size: 13px;`\n\nmsg.trStyle=`border: 1px solid #AAAAAA; padding: 3px 2px;`;\n\nmsg.tdStyle=`border: 1px solid #AAAAAA; padding: 3px 2px;`;\n\nreturn msg;",
        "outputs": 1,
        "timeout": "",
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 945,
        "y": 180,
                "33bd0017.24fa4"
        "l": false
        "id": "c46a7807.a07ad8",
        "type": "MSSQL",
        "mssqlCN": "",
        "outField": "raport02",
        "returnType": "0",
        "throwErrors": "0",
        "query": "\nselect \n Test 1 \nFrom Test 1",
        "modeOpt": "",
        "modeOptType": "query",
        "queryOpt": "",
        "queryOptType": "editor",
        "paramsOpt": "queryParams",
        "paramsOptType": "msg",
        "rows": "",
        "rowsType": "msg",
        "parseMustache": true,
        "params": [],
        "x": 305,
        "y": 180,
                "10186f43.66ff81"
        "l": false
        "id": "10186f43.66ff81",
        "type": "MSSQL",
        "mssqlCN": "",
        "outField": "raport03",
        "returnType": "0",
        "throwErrors": "0",
        "query": "\nselect \n Test 2\nFrom Test 2",
        "modeOpt": "",
        "queryOpt": "",
        "rows": "",
        "rowsType": "msg",
        "params": [],
        "x": 365,
        "y": 180,
                "31d0d7cc.138488"
        "l": false
        "id": "31d0d7cc.138488",
        "type": "MSSQL",
        "mssqlCN": "",
        "outField": "raport04",
        "returnType": "0",
        "throwErrors": "0",
        "query": "\nselect \n Test 3 \nFrom Test 3",
        "modeOpt": "",
        "queryOpt": "",
        "rows": "",
        "rowsType": "msg",
        "params": [],
        "x": 425,
        "y": 180,
                "2206a863.9f2928"
        "l": false
        "id": "2515b35f.ff580c",
        "type": "function",
        "name": "exceljs",
        "func": "msg.payload = msg.raport02;\n\nvar require = global.get('require');\nvar xl = require('exceljs');\nvar workbook = new xl.Workbook();\n\nworkbook.creator = 'NodeRed exceljs';\nworkbook.lastModifiedBy = 'NodeRed exceljs';\nworkbook.created = new Date();\nworkbook.modified = new Date();\nworkbook.lastPrinted = new Date();\n\n// create a sheet with the first row and column frozen\nvar worksheet = workbook.addWorksheet(msg.arkusz1, {views:[{state: 'frozen', ySplit:1}]});\n\n\n\nworksheet.getColumn(1).width =20;\nworksheet.getColumn(2).width =60;\nworksheet.getColumn(3).width =25;\nworksheet.getColumn(4).width =12;\nworksheet.getColumn(5).width =35;\nworksheet.getColumn(6).width =20;\nworksheet.getColumn(7).width =15;\nworksheet.getColumn(8).width =20;\nworksheet.getColumn(9).width =15;\nworksheet.getColumn(10).width =15;\nworksheet.getColumn(11).width =15;\nworksheet.getColumn(12).width =20;\nworksheet.getColumn(13).width =15;\n\n// Nazwy kolumn\nvar columns = [];\nvar col = Object.keys(msg.raport02[0]);\n\nfor(var c in col)\n{\n    columns.push({\"name\": col[c],  \"filterButton\": true});\n}\n\n\n\n\n\nvar table={\n  name: 'Raport_inwentury_Wew',\n  ref: 'A1',\n  headerRow: true,\n  totalsRow: false,\n  style: {\n    theme: 'TableStyleMedium3',\n    showRowStripes: true,\n    },\n    columns:columns,\n  rows: [],\n};\n\n\nfor(var r in msg.raport02)\n{\n    table.rows.push(Object.values(msg.raport02[r]));\n}\n\n\n//worksheet.autoFilter = 'A1:Z1';\n\nif(typeof msg.raport02!== undefined && msg.raport02 !== null && msg.raport02.length>0)\n    worksheet.addTable(table);\n\n\n/////////////////////////////////////////////////////\nvar worksheet2 = workbook.addWorksheet(msg.arkusz2, {views:[{state: 'frozen', ySplit:1}]});\n\nworksheet2.getColumn(1).width =50;\nworksheet2.getColumn(2).width =60;\nworksheet2.getColumn(3).width =25;\n\nvar columns2 = [];\nvar col2 = Object.keys(msg.raport01[0]);\n\nfor(var c2 in col2)\n{\n    columns2.push({\"name\": col2[c2],  \"filterButton\": true});\n}\n\nvar table2={\n  name: 'Raport2',\n  ref: 'A1',\n  headerRow: true,\n  totalsRow: false,\n  style: {\n    theme: 'TableStyleMedium3',\n    showRowStripes: true,\n    },\n    columns:columns2,\n  rows: [],\n};\n\nfor(var r2 in msg.raport01)\n{\n    table2.rows.push(Object.values(msg.raport01[r2]));\n}\n\n if(typeof msg.raport01!== undefined && msg.raport01 !== null && msg.raport01.length>0)\n     worksheet2.addTable(table2);\n\n\n\n\n\n/////////////////////////////////////////////////////\nvar worksheet3 = workbook.addWorksheet(msg.arkusz3, {views:[{state: 'frozen', ySplit:1}]});\n\nworksheet3.getColumn(1).width =20;\nworksheet3.getColumn(2).width =20;\nworksheet3.getColumn(3).width =75;\nworksheet3.getColumn(4).width =85;\nworksheet3.getColumn(5).width =25;\nworksheet3.getColumn(6).width =25;\nworksheet3.getColumn(7).width =15;\n\nvar columns3 = [];\nvar col3 = Object.keys(msg.raport03[0]);\n\nfor(var c3 in col3)\n{\n    columns3.push({\"name\": col3[c3],  \"filterButton\": true});\n}\n\n\n\n\n\nvar table3={\n  name: 'Raport3',\n  ref: 'A1',\n  headerRow: true,\n  totalsRow: false,\n  style: {\n    theme: 'TableStyleMedium3',\n    showRowStripes: true,\n    },\n    columns:columns3,\n  rows: [],\n};\n\n\n\n\nfor(var r3 in msg.raport03)\n{\n    table3.rows.push(Object.values(msg.raport03[r3]));\n}\n\n\n\n\n\nif(typeof msg.raport03 !== undefined && msg.raport03 !== null && msg.raport03.length>0)\n    worksheet3.addTable(table3);\n\n\n////////////////////////////\n//////////////////////////\n/////////////////////////////\n\nvar worksheet4 = workbook.addWorksheet(msg.arkusz4, {views:[{state: 'frozen', ySplit:1}]});\n\nworksheet4.getColumn(1).width =20;\nworksheet4.getColumn(2).width =20;\nworksheet4.getColumn(3).width =75;\nworksheet4.getColumn(4).width =85;\nworksheet4.getColumn(5).width =25;\nworksheet4.getColumn(6).width =25;\nworksheet4.getColumn(7).width =15;\n\nvar columns4 = [];\nvar col4 = Object.keys(msg.raport04[0]);\n\nfor(var c4 in col4)\n{\n    columns4.push({\"name\": col4[c4],  \"filterButton\": true});\n}\n\n\n\n\n\nvar table4={\n  name: 'Raport4',\n  ref: 'A1',\n  headerRow: true,\n  totalsRow: false,\n  style: {\n    theme: 'TableStyleMedium3',\n    showRowStripes: true,\n    },\n    columns:columns4,\n  rows: [],\n};\n\n\n\n\nfor(var r4 in msg.raport04)\n{\n    table4.rows.push(Object.values(msg.raport04[r4]));\n}\n\n\n\n\n\nif(typeof msg.raport04 !== undefined && msg.raport04 !== null && msg.raport04.length>0)\n    worksheet4.addTable(table4);\n\n\n\n////////////\n\n////////////////////////////\n//////////////////////////\n/////////////////////////////\n\nvar worksheet5 = workbook.addWorksheet(msg.arkusz5, {views:[{state: 'frozen', ySplit:1}]});\n\nworksheet5.getColumn(1).width =20;\nworksheet5.getColumn(2).width =20;\nworksheet5.getColumn(3).width =75;\nworksheet5.getColumn(4).width =85;\nworksheet5.getColumn(5).width =25;\nworksheet5.getColumn(6).width =25;\nworksheet5.getColumn(7).width =15;\n\nvar columns5 = [];\nvar col5 = Object.keys(msg.raport05[0]);\n\nfor(var c5 in col5)\n{\n    columns5.push({\"name\": col5[c5],  \"filterButton\": true});\n}\n\n\n\n\n\nvar table5={\n  name: 'Raport5',\n  ref: 'A1',\n  headerRow: true,\n  totalsRow: false,\n  style: {\n    theme: 'TableStyleMedium3',\n    showRowStripes: true,\n    },\n    columns:columns5,\n  rows: [],\n};\n\n\n\n\nfor(var r5 in msg.raport05)\n{\n    table5.rows.push(Object.values(msg.raport05[r5]));\n    \n    \n}\n\n\n\n\n\nif(typeof msg.raport05 !== undefined && msg.raport05 !== null && msg.raport05.length>0)\n    worksheet5.addTable(table5);\n\n\n \n\nvar worksheet6 = workbook.addWorksheet(msg.arkusz6, {views:[{state: 'frozen', ySplit:1}]});\n\nworksheet5.getColumn(1).width =20;\nworksheet5.getColumn(2).width =20;\nworksheet5.getColumn(3).width =75;\nworksheet5.getColumn(4).width =85;\nworksheet5.getColumn(5).width =25;\nworksheet5.getColumn(6).width =25;\nworksheet5.getColumn(7).width =15;\n\nvar columns6 = [];\nvar col6 = Object.keys(msg.raport06[0]);\n\nfor(var c6 in col6)\n{\n    columns6.push({\"name\": col6[c6],  \"filterButton\": true});\n}\n\n\n\n\n\nvar table6={\n  name: 'Raport6',\n  ref: 'A1',\n  headerRow: true,\n  totalsRow: false,\n  style: {\n    theme: 'TableStyleMedium3',\n    showRowStripes: true,\n    },\n    columns:columns6,\n  rows: [],\n};\n\n\n\n\nfor(var r6 in msg.raport06)\n{\n    table6.rows.push(Object.values(msg.raport06[r6]));\n    \n    \n}\n\n\n\n\n\nif(typeof msg.raport06 !== undefined && msg.raport06 !== null && msg.raport06.length>0)\n    worksheet6.addTable(table6);\n\n\n\nvar worksheet7 = workbook.addWorksheet(msg.arkusz7, {views:[{state: 'frozen', ySplit:1}]});\n\nworksheet5.getColumn(1).width =20;\nworksheet5.getColumn(2).width =20;\nworksheet5.getColumn(3).width =75;\nworksheet5.getColumn(4).width =85;\nworksheet5.getColumn(5).width =25;\nworksheet5.getColumn(6).width =25;\nworksheet5.getColumn(7).width =15;\n\nvar columns7 = [];\nvar col7 = Object.keys(msg.raport07[0]);\n\nfor(var c7 in col7)\n{\n    columns7.push({\"name\": col7[c7],  \"filterButton\": true});\n}\n\n\n\n\n\nvar table7={\n  name: 'Raport7',\n  ref: 'A1',\n  headerRow: true,\n  totalsRow: false,\n  style: {\n    theme: 'TableStyleMedium3',\n    showRowStripes: true,\n    },\n    columns:columns7,\n  rows: [],\n};\n\n\n\n\nfor(var r7 in msg.raport07)\n{\n    table7.rows.push(Object.values(msg.raport07[r7]));\n    \n    \n}\n\n\n\n\n\nif(typeof msg.raport07 !== undefined && msg.raport07 !== null && msg.raport07.length>0)\n    worksheet7.addTable(table7);\n\n\n\n\n\n\nworkbook.xlsx.writeBuffer()\n  .then(function(buffer) {\n    msg.excel=buffer;\n    node.send(msg);\n});\n\n",
        "outputs": 1,
        "timeout": "",
        "noerr": 3,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 885,
        "y": 280,
                "7549c41c.03690c"
        "l": false
ADMIN EDIT: Wrap flows in triple backticks to make it importable
Hi, firstly your flow was not correctly formatted for the forum so I corrected it for you
In order to make code readable and usable it is necessary to surround your code with three backticks (also known as a left quote or backquote ```)
   code goes here
You can edit and correct your post by clicking the pencil :pencil: icon.
Next, I moved this thread to General since you are not Developing Nodes
Lastly, require is NOT really recommended or even necessary. I would use the Setup tab and add your npm module in there. See the below article for how to:
I think there is a 'not' missing there.
