I'm using node-red and want to create an interface as follows:
When selecting machine 1 and then clicking Load Report, it should display a table. However, when clicking Load Report, the "date" and "shift" data received from Firebase are not passed into the table. Interestingly, if I create the table without the dropdown and button, the "date" and "shift" data can still be passed into the table.
This is my node-red:
And this's code in Addional Row
var showTable = false;
if (msg.payload === "Machine 1") {
showTable = true;
} else {
showTable = false;
if (showTable === true ) {
var tableData
tableData = flow.get('savedData') || [];
tableData.unshift (
date : msg.payload.date,
shift : msg.payload.shift
msg.payload = tableData;
flow.set('savedData', tableData);
