Heres what im trying to accomplish; I want an Actionable IOS notification sent when I leave home (tracked by life360). The choices on that IOS notification would be; "WALK" and "AWAY".
If "WALK" selected do X
if "AWAY" selected do Y
Heres what I got (obviously not working). Forgive any noob mistakes.. I've just recently got into HA and NR. Any help is greatly appreciated.
/configuration.yaml
ios:
push:
categories:
- name: Walk or Away?
identifier: 'AWAYWALK'
actions:
- identifier: 'WALK_MODE'
title: 'Walk Mode'
- identifier: 'AWAY_MODE'
title: 'Set Away Mode'
destructive: true
/automations.yaml
- alias: Walk or Away Mode Set Button
initial_state: true
trigger:
condition:
condition: state
entity_id: device_tracker.life360_jon
state: not_home
action:
service: notify.mobile_app_jc_xs
data:
title: "You have left! Select Mode"
message: "On a Walk, or Away?"
data:
push:
badge: 0
category: 'AWAYWALK'
- alias: IOS app notification WALK MODE
initial_state: true
trigger:
platform: event
event_type: ios_notification_action_fired
event_data:
actioName: WALK_MODE
action:
service: input_select.select_option
entity_id: input_select.away_or_on_a_walk_notification_select
option: iswalk
- alias: IOS app notification AWAY MODE
initial_state: true
trigger:
platform: event
event_data:
actioName: AWAY_MODE
action:
option: isaway
Heres the basic flow sequence:
[{"id":"da27185.bd465e8","type":"tab","label":"Flow 1","disabled":false,"info":""},{"id":"c27d3ce6.5a91b","type":"server-state-changed","z":"da27185.bd465e8","name":"IOS Choice WALK or AWAY?","server":"41c2e4cc.1954cc","version":1,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"input_select.away_or_on_a_walk_notification_select","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"x":240,"y":340,"wires":[["a4fad94.ec93728"]]},{"id":"a4fad94.ec93728","type":"switch","z":"da27185.bd465e8","name":"Choice from Device","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"isaway","vt":"str"},{"t":"eq","v":"iswalk","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":470,"y":340,"wires":[["d4fe3b99.f17128"],["1252adb5.ae5f02"]]},{"id":"1252adb5.ae5f02","type":"debug","z":"da27185.bd465e8","name":"To Cater Walk Mode >>>","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":710,"y":480,"wires":[]},{"id":"d4fe3b99.f17128","type":"debug","z":"da27185.bd465e8","name":"To Away Mode >>","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":710,"y":180,"wires":[]},{"id":"41c2e4cc.1954cc","type":"server","z":"","name":"Home Assistant","legacy":false,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true}]
So, Im not even getting the notification at this point. I use normal IOS notifications in many other areas without issue, so I'm not sure whats going on here.. I accidently cleared the log, but ill post it once it populates again.
Im just posting this in case anyone sees some clear and obvious problems or poor scripting.
Also, if anyone has a better way to test this.. the whole "Change State" trigger based off life360 (with my flow) is annoying cause I keep changing my "home" in life360. Not sure how to Inject> a state change.
Thanks in advance!
