I'm having some trouble injecting JSON into a Python script being executed using the Exec node. The JSON is held in a template node. I've read all the other forum posts on this and similar but I am still hitting a dead end. The Flow JSON and (very simple) Python script are below.
Any help to resolve this would be most gratefully received
The flow JSON:
"id": "7f8485d6fdbb1016",
"type": "tab",
"label": "Syspro Business Objects",
"disabled": false,
"info": "",
"env": []
"id": "72ba41ac93f463b6",
"type": "inject",
"z": "7f8485d6fdbb1016",
"name": "Inject",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "",
"payload": "",
"payloadType": "date",
"x": 170,
"y": 160,
"432ef353974e0f43"
"id": "3dc73cd34e6c9e81",
"type": "debug",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "payload",
"targetType": "msg",
"statusVal": "",
"statusType": "auto",
"x": 770,
"y": 160,
"id": "7c06188252ebc2f3",
"type": "exec",
"command": "python D:\\Python\\Syspro\\SORQRY.py ",
"addpay": "payload",
"append": "",
"useSpawn": "false",
"timer": "",
"winHide": false,
"oldrc": false,
"name": "SORQRY",
"x": 580,
"y": 160,
"3dc73cd34e6c9e81"
"3dc73cd34e6c9e81"
"3dc73cd34e6c9e81"
"id": "432ef353974e0f43",
"type": "template",
"name": "SORQRY_params",
"field": "payload",
"fieldType": "msg",
"format": "json",
"syntax": "mustache",
"template": "{\n \"Key\":{\n \"SalesOrder\":\"000231\"\n },\n \"Options\":{\n \"DatabaseLetter\":\"T\",\n \"OutputFormat\":\"JSON\",\n \"IncludeStockedLines\":\"Y\",\n \"IncludeNonStockedLines\":\"Y\",\n \"IncludeFreightLines\":\"Y\",\n \"IncludeMiscLines\":\"Y\",\n \"IncludeCommentLines\":\"Y\",\n \"IncludeCompletedLines\":\"Y\",\n \"IncludeSerials\":\"N\",\n \"IncludeLots\":\"Y\",\n \"IncludeBins\":\"Y\",\n \"IncludeAttachedItems\":\"N\",\n \"IncludeCustomForms\":\"Y\",\n \"IncludeDetailLineCustomForms\":\"Y\",\n \"IncludeValues\":\"N\",\n \"ReturnLineShipDate\":\"N\"\n }\n}",
"output": "json",
"x": 370,
"y": 160,
"7c06188252ebc2f3"
The Python script:
import json
import sys
# read json payload from first commend line parameter
json_payload = sys.argv[1:]
data_dict = json_payload.json()
key_SalesOrder = data_dict["Key"]["SalesOrder"]
option_DatabaseLetter = data_dict["Options"]["DatabaseLetter"]
option_OutputFormat = data_dict["Options"]["OutputFormat"]
print("{")
print(" 'Key': '" + key_SalesOrder + "'," )
print(" 'DatabaseLetter': '" + option_DatabaseLetter + "'" )
print("}")
