Problema con pulsante
@ivanpesenti, please can you post code correctly
No one can help if half your code does not show up, or is corrupted.
Also can you confirm what thei is about. Is it developing a node, dashboard or just serving up a html page.
If ui-template code you do not need <html> or <body> tags.
   code goes here
You can edit and correct your post by clicking the pencil :pencil2: icon.
