I am trying to get the data contained in the events in this object:
If I copy the path of the first object (0: object) it gives me: area.info.events[0]
But when I run the function:
msg.payload = msg.area.info.events.map(event => {
return {
start: event.start,
end: event.end,
note: event.note
I get "TypeError: Cannot read properties of undefined (reading 'info')"
The path looks correct to me. What am I doing wrong?
Use the "copy path" tools node-red provides to ensure correct path.
There’s a great page in the docs (Working with messages : Node-RED) that will explain how to use the debug panel to find the right path to any data item.
Additionally, use node.warn in your function e.g. node.warn({"msg.area": msg.area}) just before you access it.
Lastly, this is easier with the split and join nodes
Thanks but I copied the path “ If I copy the path of the first object (0: object) it gives me: area.info.events[0]”
That confirms that message contained .area.info.events and it was an array THIS TIME, but as you did see the below error at some point _
_ it suggests a previous msg came through WITHOUT .area resulting in a type error (that is literally what the error says - couldnt read info from undefined i.e. msg.area was undefined & why I said to add node.warn({"msg.area": msg.area}) just before you access it.
If you think there are places a msg could come through that sometimes does NOT have the area property, and that is OK, then you will need to guard against it.
e.g... add a switch node before the function that checks msg.area is type of object OR in your function:
if (!Array.isArray(msg.area?.info?.events)) {
node.error("msg.area.info.events is NOT an array!", msg) // throw catchable error
return null // halt the flow
// original code below
return msg
