Problems With Adding Additional nodes with @sammachin/node-red-matter-bridge
I have been happily using these nodes for a while so I start transferring additional Alexa items. I got to a point where Node-RED crashed, I am not sure what happened exactly but I was adding a node-red-matter-bridge temperature node when it happened. I am now in the position that any additional node-red-matter-bridge node that I add causes Node-RED to crash.
If I start node-RED in safe mode I see a
2025-11-02 19:33:39.704 ERROR StorageBac~DiskAsync Failed to parse storage value for key number in context root.parts.aggregator.parts.f7d53c1574740d86
error (or similar) in the start-up log and on investigation the file is 0 bytes long (node-RED still runs OK).
This leads me to suspect that some tracking mechanism in the node addition process has got corrupt.
@sammachin will I have to start from scratch or is there a way to fix this?
Here is part of one of the crash logs (I have the complete log if required)
2025-11-02 19:14:41.095 ERROR  StorageBac~DiskAsync Failed to parse storage value for key subscriptions in context root.subscription
2 Nov 19:14:41 - [info] [mattersubscribe:Matter To System] Setting Subscription...
2025-11-02 19:14:41.166 ERROR  StorageBac~DiskAsync Failed to parse storage value for key __number__ in context root.parts.aggregator.parts.6cf217ff73a8d56a
2025-11-02 19:14:41.348 ERROR  StorageBac~DiskAsync Failed to parse storage value for key lastEventNumber in context events
2 Nov 19:14:41 - [info] [matterbridge:Alexa] Bridge Created, awaiting child nodes
2025-11-02 19:32:56.234 ERROR  Transaction          Rolling back initialize<146dfb1d68c407e0.aggregator.f7d53c1574740d86>#2cd9 due to error: Behaviors have errors
2 Nov 19:32:56 - [info] Started modified nodes
2025-11-02 19:32:56.240 FATAL  Logger               Unhandled error detected: Behaviors have errors
  at /home/pi/.node-red/node_modules/@sammachin/node-red-matter-bridge/node_modules/@matter/node/dist/cjs/endpoint/properties/Behaviors.js:139:21
  at all (/home/pi/.node-red/node_modules/@sammachin/node-red-matter-bridge/node_modules/@matter/general/dist/cjs/util/Construction.js:404:17)
  at /home/pi/.node-red/node_modules/@sammachin/node-red-matter-bridge/node_modules/@matter/general/dist/cjs/util/Construction.js:394:11
  Cause #0: Error initializing 146dfb1d68c407e0.aggregator.f7d53c1574740d86.temperatureMeasurement
    at crash (/home/pi/.node-red/node_modules/@sammachin/node-red-matter-bridge/node_modules/@matter/node/dist/cjs/behavior/internal/BehaviorBacking.js:77:22)
    at [construct] (/home/pi/.node-red/node_modules/@sammachin/node-red-matter-bridge/node_modules/@matter/node/dist/cjs/behavior/internal/BehaviorBacking.js:88:7)
    at initializeDeferred (/home/pi/.node-red/node_modules/@sammachin/node-red-matter-bridge/node_modules/@matter/general/dist/cjs/util/Construction.js:86:73)
    at invokeInitializer (/home/pi/.node-red/node_modules/@sammachin/node-red-matter-bridge/node_modules/@matter/general/dist/cjs/util/Construction.js:306:26)
    at AsyncConstruction.start (/home/pi/.node-red/node_modules/@sammachin/node-red-matter-bridge/node_modules/@matter/general/dist/cjs/util/Construction.js:87:9)
    at #createBacking (/home/pi/.node-red/node_modules/@sammachin/node-red-matter-bridge/node_modules/@matter/node/dist/cjs/endpoint/properties/Behaviors.js:454:26)
    at Behaviors.activate (/home/pi/.node-red/node_modules/@sammachin/node-red-matter-bridge/node_modules/@matter/node/dist/cjs/endpoint/properties/Behaviors.js:259:26)
    at initializeBehaviors (/home/pi/.node-red/node_modules/@sammachin/node-red-matter-bridge/node_modules/@matter/node/dist/cjs/endpoint/properties/Behaviors.js:130:16)
    at actOffline (/home/pi/.node-red/node_modules/@sammachin/node-red-matter-bridge/node_modules/@matter/node/dist/cjs/behavior/context/server/OfflineContext.js:57:14)
    at Transaction.act (/home/pi/.node-red/node_modules/@sammachin/node-red-matter-bridge/node_modules/@matter/general/dist/cjs/transaction/Tx.js:91:25)
    at OfflineContext.act (/home/pi/.node-red/node_modules/@sammachin/node-red-matter-bridge/node_modules/@matter/node/dist/cjs/behavior/context/server/OfflineContext.js:62:49)
    at Behaviors.initialize (/home/pi/.node-red/node_modules/@sammachin/node-red-matter-bridge/node_modules/@matter/node/dist/cjs/endpoint/properties/Behaviors.js:151:56)
    at Endpoint.initialize (/home/pi/.node-red/node_modules/@sammachin/node-red-matter-bridge/node_modules/@matter/node/dist/cjs/endpoint/Endpoint.js:510:34)
    at [construct] (/home/pi/.node-red/node_modules/@sammachin/node-red-matter-bridge/node_modules/@matter/node/dist/cjs/endpoint/Endpoint.js:535:17)
    at Parts.add (/home/pi/.node-red/node_modules/@sammachin/node-red-matter-bridge/node_modules/@matter/node/dist/cjs/endpoint/properties/Parts.js:58:29)
    at Endpoint.add (/home/pi/.node-red/node_modules/@sammachin/node-red-matter-bridge/node_modules/@matter/node/dist/cjs/endpoint/Endpoint.js:345:16)
  Caused by: Validating 146dfb1d68c407e0.aggregator.f7d53c1574740d86.temperatureMeasurement.state.measuredValue: Constraint "minMeasuredValue to maxMeasuredValue": Value 0 is not within bounds defined by constraint (135)
    at /home/pi/.node-red/node_modules/@sammachin/node-red-matter-bridge/node_modules/@matter/node/dist/cjs/behavior/state/validation/constraint.js:76:17
    at /home/pi/.node-red/node_modules/@sammachin/node-red-matter-bridge/node_modules/@matter/node/dist/cjs/behavior/state/validation/ValueValidator.js:169:25
    at /home/pi/.node-red/node_modules/@sammachin/node-red-matter-bridge/node_modules/@matter/node/dist/cjs/behavior/state/validation/ValueValidator.js:98:24
    at Object.measuredValue (/home/pi/.node-red/node_modules/@sammachin/node-red-matter-bridge/node_modules/@matter/node/dist/cjs/behavior/state/validation/conformance.js:38:22)
    at validateStruct (/home/pi/.node-red/node_modules/@sammachin/node-red-matter-bridge/node_modules/@matter/node/dist/cjs/behavior/state/validation/ValueValidator.js:204:23)
    at Object.validate (/home/pi/.node-red/node_modules/@sammachin/node-red-matter-bridge/node_modules/@matter/node/dist/cjs/behavior/state/managed/Datasource.js:59:7)
    at finalizeState (/home/pi/.node-red/node_modules/@sammachin/node-red-matter-bridge/node_modules/@matter/node/dist/cjs/behavior/internal/ServerBehaviorBacking.js:62:23)
    at ServerBehaviorBacking.invokeInitializer (/home/pi/.node-red/node_modules/@sammachin/node-red-matter-bridge/node_modules/@matter/node/dist/cjs/behavior/internal/ServerBehaviorBacking.js:68:5)
    at [construct] (/home/pi/.node-red/node_modules/@sammachin/node-red-matter-bridge/node_modules/@matter/node/dist/cjs/behavior/internal/BehaviorBacking.js:83:28)
    (see parent frames)
2025-11-02 19:32:56.244 FATAL  Logger               Unhandled error detected: Behaviors have errors
    (see parent frames)
[red] Uncaught Exception:
2 Nov 19:32:56 - [error] AggregateError: Behaviors have errors
I saved the flow with these nodes and then deleted the whole lot, uninstalled bridge nodes & deleted the .matter.virtual directory.
I then reinstalled the bridge nodes and imported the saved flows. I then edited one of the nodes to include the new bridge and got the joining code & QR code. This enabled me to reconnect the nodes to the Alexa app. Bingo. All I had to do then has add the correct bridge to all the nodes (all 40 of them)
I now have a system connected to 2 Alexa systems & Google Home. Yipee
