Problems with node-red-contrib-subflow2node
408 / 5.000
I've been using the example you suggested, and it works fine. However, I create my own subflow, and when I try to import the .tgz file, I get this error:
"[node-red-contrib-oscar-cluster-logs/oscar-logs] TypeError: Cannot set properties of undefined (setting 'type') (line: 81)"
I've defined the node type the same as in the example, and the created node still doesn't work properly.
Regards, Vicente
