I am new to node red, have converted xlsx file into json format. Now i want to read this json data row wise with certain conditions. Also date is coming as 44548, want to convert it in dd/mm/yyyy format.
Please help
Hi, I'm afraid that you might not get many responses as you've added this to a three-year-old thread. Moving to a new thread for you - can you please update the title to reflect your question? Thanks.
This is not a specific NodeRed question. It relates to javascript or nodejs programming.
In addition, an example of the JSON could always help.
Thanks, I am new to this so again thanks
Could you use a debug node, copy the output, and paste it here, so we can see exactly what data you are trying to work with.
Before pasting it, click on the </> icon in the forum post window, and paste your data where indicated.
Need date conversion help too
Date is 44548
1/1/1970 or 1/1/1900 is the reference point
Yes, need help in javascript/ node red
Seems like someone has already done the javascipt.
Check out the code on Github:
excel-date-to-js
Yes, there are several edge-cases so best to use a well tried library.
Not able to solve the problem of reading the xlsx file in alsql node in node red
Thanks, right now stuck at " reading the xlsx file thru alasql node in node-red"
Thanks for helping
Not able to use PATINDEX fn
Err: alasql.fn.PATINDEX is not a function
Thanks a lot
