Publishing Foto from ESP32Cam to Dashboard via mqtt
Hi
what is wrong on my flow???
        "id": "1e03ce048d71e10b",
        "type": "ui_template",
        "z": "fcb20266.ce938",
        "group": "",
        "name": "show image",
        "order": 4,
        "width": "0",
        "height": "0",
        "format": "<img height=\"100%\" src=\"data:image/jpeg;base64,{{msg.payload}}\" />",
        "storeOutMessages": true,
        "fwdInMessages": true,
        "resendOnRefresh": true,
        "templateScope": "local",
        "x": 790,
        "y": 600,
        "id": "5e8b13a9fea4b33e",
        "type": "base64",
        "action": "",
        "property": "payload",
        "x": 520,
        "y": 600,
                "1e03ce048d71e10b"
        "id": "c3c37cbc9b948369",
        "type": "debug",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "false",
        "statusVal": "",
        "statusType": "auto",
        "x": 550,
        "y": 660,
        "id": "a6b455bd1ca3d44a",
        "type": "mqtt in",
        "name": "Photo",
        "topic": "door/photo",
        "qos": "2",
        "datatype": "auto",
        "broker": "07d3db087409f398",
        "nl": false,
        "rap": true,
        "rh": 0,
        "inputs": 0,
        "x": 190,
        "y": 600,
                "5e8b13a9fea4b33e",
                "c3c37cbc9b948369"
        "id": "07d3db087409f398",
        "type": "mqtt-broker",
        "name": "Door",
        "broker": "192.168.1.101",
        "port": "1883",
        "clientid": "",
        "autoConnect": true,
        "usetls": false,
        "protocolVersion": "4",
        "keepalive": "60",
        "cleansession": true,
        "birthTopic": "",
        "birthQos": "0",
        "birthRetain": "false",
        "birthPayload": "",
        "birthMsg": {},
        "closeTopic": "",
        "closeQos": "0",
        "closeRetain": "false",
        "closePayload": "",
        "closeMsg": {},
        "willTopic": "",
        "willQos": "0",
        "willRetain": "false",
        "willPayload": "",
        "willMsg": {},
        "sessionExpiry": ""
the ESP32-Cam sent a foto with the following sketch:
void take_picture() {
camera_fb_t * fb = NULL; // pointer
Serial.println("Taking a photo...");
fb = esp_camera_fb_get();
if (!fb) {
Serial.println("Camera capture failed");
return;
if (MQTT_MAX_PACKET_SIZE == 128) {
//SLOW MODE (increase MQTT_MAX_PACKET_SIZE)
client.publish_P("door/photo", fb->buf, fb->len, false);
Serial.print("SLOW MODE ");
else {
//FAST MODE (increase MQTT_MAX_PACKET_SIZE)
client.publish("door/photo", fb->buf, fb->len, false);
Serial.print("FAST MODE ");
Serial.print(" message and Foto sent... ");
esp_camera_fb_return(fb);
the ESP-Cam show's in the serial-monitor a successful capture and sending
18:44:40.788 -> Connecting to WiFi...
18:44:40.788 -> Initializing the camera module...init Cam..1..
18:44:41.100 -> Camera init successfully
18:44:41.100 -> Ok!
18:44:41.100 -> IP Address: http//192.168.1.69
18:44:41.100 -> Attempting MQTT connection...connected
18:44:51.319 -> Ring-Button Pressed
18:44:51.319 -> Taking a photo...
18:44:51.387 -> FAST MODE message and Foto sent... Message arrived on topic: door/comming. Message: on
no item will be listed in the Node-Red-Log and no message are given in the Node-Red Debug-list !!!
Node-Red-Log:
6 Mar 17:58:00 - [info] Started flows
6 Mar 17:58:01 - [info] [mqtt-broker:Door] Connected to broker: mqtt://192.168.1.101:1883
6 Mar 17:58:01 - [info] [mqtt-broker:0a052b42825e3cd5] Connected to broker: mqtt://192.168.1.101:1883
the ESP32-Cam ist tested, as a http-Webserver he are sending normal pictures
Examples in Github: botabotlab/ ESP32CAM-MQTT also doesn't show's a picture in the Dashboard/Template - and - tested by an independent body with the same result, no photo in the template!
many thanks in advance for further informations
