I'm trying to add a Query string the url from a payload response, but kind of stuck. Any help is much appreciated. object
Response Debug
_msgid: "1db80dc515d48aaf"
payload: object
headers: object
query: "var query = msg.payload.dealReference↵return msg.↵"
statusCode: 400
responseUrl: "https://demo-api-capital.backend-capital.com/api/v1/confirms/var%20query%20=%20msg.payload.dealReferencereturn%20msg."
redirectList: array[0]
retry: 0
Template node ;
return msg.
To pass a query string to a request node, you need to add the query to the URL. So the input msg needs to have a msg.url (which you could build dynamically by using JSONata in a change node) or you can specify the URL in the node and use mustache style variables:
https://demo-api-capital.backend-capital.com/api/v1/confirms/{{{payload.dealReference}}}
Note that msg. is not supplied in the mustache variables. Also note that using double brackets {{...}} would man that mustache would escape any characters that would be mis-interpreted as HTML which is why triple-brackets are needed.
Category changed to general, as this post is not about creating nodes.
