NR 2.0.1
Dashboard 2.28.1
Is there a way to set a default/start option?
Say I have 5 options.
I want #2 to be the selected as default.
How?
Reading the docs I can't work out how to do this.
NR 2.0.1
Dashboard 2.28.1
How?
Feeding in payload set to the value of the option you wish preselected should work according to the help info in the side panel
Setting
msg.payloadto one of the item values will preset the choice in the dropdown. If using the multi-select option then the payload should be an array of values.
e.g. sets option 3 to preset
[{"id":"f441c974.c69d58","type":"inject","z":"b779de97.b1b46","name":"","props":[{"p":"payload"},{"p":"options","v":"[1,2,3,4]","vt":"json"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"3","payloadType":"num","x":110,"y":4900,"wires":[["b8f62a0d.697b38"]]},{"id":"b8f62a0d.697b38","type":"ui_dropdown","z":"b779de97.b1b46","name":"","label":"","tooltip":"","place":"Select option","group":"8b5cde76.edd58","order":12,"width":0,"height":0,"passthru":true,"multiple":false,"options":[],"payload":"","topic":"topic","topicType":"msg","x":180,"y":4940,"wires":[[]]},{"id":"8b5cde76.edd58","type":"ui_group","name":"","tab":"8f03e639.85956","order":1,"disp":true,"width":"12","collapse":false},{"id":"8f03e639.85956","type":"ui_tab","name":"Home","icon":"dashboard","disabled":false,"hidden":false}]
Strange I didn't understand what was written in the info panel to say that could be done.
