Raspberry Pi, freeing up unused memory sooner
This might be a hardware question. node-red-pi --max-old-space-size=256
Does that need to be run every time?
Source: Running on Raspberry Pi : Node-RED
If you installed node-red using the recommended script then it will have installed a systemd script that will do that for you if you start/stop using
node-red-start
node-red-stop
and tell it to autostart on boot
sudo systemctl enable nodered
