Rbe deadband stops first message
Yes I think it should pass the first message through.
the fix is fairly simple if you want to manually edit.
Find the file rbe.js in your .node-red/node_modules/node-red-node-rbe directory and fix line 57 to be
 if (node.previous[t] === undefined) { node.previous[t] = n - node.gap - 1; }
IE add the -1 to the existing line (which forces the initial value to always be outside the range and thus get sent. I'll fix the node and update it soon.
Fixed in version v0.2.9
Thank you all for your input.
And thank you @dceejay for the quick remedy. Working good for me!
