Hi!
I am struggeling with the rbe node. A ZigBee device is sending periodical status messages with "msg.payload.state" ON or OFF. Sometimes it sends >5 mesages at once. So I tried to use a rbe to suppress all of these redundant mesages ("block unless values changes"). But it is not working. Every message passes through the RBE node, even though nothing has changed in the payload.
These four messages are all let through:
{"device":"Girier_1","payload":{"device":{"applicationVersion":67,"dateCode":"","friendlyName":"Girier_1","hardwareVersion":1,"ieeeAddr":"0xa4c1386b3db8e04b","manufacturerID":4417,"manufacturerName":"_TZ3000_6axxqqi2","model":"JR-ZDS01","networkAddress":22928,"powerSource":"Mains (single phase)","stackVersion":0,"type":"Router","zclVersion":3},"last_seen":"2024-02-09T16:41:46+01:00","linkquality":131,"power_on_behavior":"off","state":"OFF","switch_type":"toggle"},"_msgid":"7999b655a8b573c0"}
{"device":"Girier_1","payload":{"device":{"applicationVersion":67,"dateCode":"","friendlyName":"Girier_1","hardwareVersion":1,"ieeeAddr":"0xa4c1386b3db8e04b","manufacturerID":4417,"manufacturerName":"_TZ3000_6axxqqi2","model":"JR-ZDS01","networkAddress":22928,"powerSource":"Mains (single phase)","stackVersion":0,"type":"Router","zclVersion":3},"last_seen":"2024-02-09T16:41:46+01:00","linkquality":131,"power_on_behavior":"off","state":"OFF","switch_type":"toggle"},"_msgid":"3b47012b92abc295"}
{"device":"Girier_1","payload":{"device":{"applicationVersion":67,"dateCode":"","friendlyName":"Girier_1","hardwareVersion":1,"ieeeAddr":"0xa4c1386b3db8e04b","manufacturerID":4417,"manufacturerName":"_TZ3000_6axxqqi2","model":"JR-ZDS01","networkAddress":22928,"powerSource":"Mains (single phase)","stackVersion":0,"type":"Router","zclVersion":3},"last_seen":"2024-02-09T16:41:46+01:00","linkquality":131,"power_on_behavior":"off","state":"OFF","switch_type":"toggle"},"_msgid":"504915da83224636"}
{"device":"Girier_1","payload":{"device":{"applicationVersion":67,"dateCode":"","friendlyName":"Girier_1","hardwareVersion":1,"ieeeAddr":"0xa4c1386b3db8e04b","manufacturerID":4417,"manufacturerName":"_TZ3000_6axxqqi2","model":"JR-ZDS01","networkAddress":22928,"powerSource":"Mains (single phase)","stackVersion":0,"type":"Router","zclVersion":3},"last_seen":"2024-02-09T16:41:46+01:00","linkquality":131,"power_on_behavior":"off","state":"OFF","switch_type":"toggle"},"_msgid":"444a735744519207"}
