as msg.payload.result is an array of objects, you could use Array.find() prototype.
Here is an example...
[{"id":"ff8f07f0.a4d518","type":"inject","z":"ade1a96c.062848","name":"Emulate data source","topic":"","payload":"{ \"result\" : [ { \"DimmerLevels\" : \"none\", \"IsDimmer\" : false, \"Name\" : \"voice_vorstalarm\", \"SubType\" : \"Switch\", \"Type\" : \"Light/Switch\", \"idx\" : \"1163\" }, { \"DimmerLevels\" : \"none\", \"IsDimmer\" : false, \"Name\" : \"voice_wasmachine\", \"SubType\" : \"Switch\", \"Type\" : \"Light/Switch\", \"idx\" : \"1149\" }, { \"DimmerLevels\" : \"none\", \"IsDimmer\" : false, \"Name\" : \"voordeurbel\", \"SubType\" : \"Switch\", \"Type\" : \"Light/Switch\", \"idx\" : \"1182\" }, { \"DimmerLevels\" : \"none\", \"IsDimmer\" : false, \"Name\" : \"vriezer\", \"SubType\" : \"Switch\", \"Type\" : \"Light/Switch\", \"idx\" : \"469\" }, { \"DimmerLevels\" : \"none\", \"IsDimmer\" : false, \"Name\" : \"wasmachine\", \"SubType\" : \"Switch\", \"Type\" : \"Light/Switch\", \"idx\" : \"976\" }, { \"DimmerLevels\" : \"none\", \"IsDimmer\" : false, \"Name\" : \"wii_lan_ip\", \"SubType\" : \"AC\", \"Type\" : \"Lighting 2\", \"idx\" : \"288\" } ], \"status\" : \"OK\", \"title\" : \"GetLightSwitches\" }","payloadType":"json","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":762,"y":120,"wires":[["eb5252e1.cb8a1"]]},{"id":"e4e6698a.662c58","type":"debug","z":"ade1a96c.062848","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":1226,"y":168,"wires":[]},{"id":"9b19d12b.8b225","type":"function","z":"ade1a96c.062848","name":"find","func":"let arr = msg.payload.result;\nlet find = msg.find;\nlet found = arr.find(function(o,i){\n return o.Name == find\n})\nif(found){\n msg.payload = found\n return [msg,null];\n}\n\nnode.warn(`could not find '${msg.find}'`);","outputs":1,"noerr":0,"x":1202,"y":120,"wires":[["e4e6698a.662c58"]]},{"id":"eb5252e1.cb8a1","type":"change","z":"ade1a96c.062848","name":"find voice_vorstalarm","rules":[{"t":"set","p":"find","pt":"msg","to":"voice_vorstalarm","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":988,"y":120,"wires":[["9b19d12b.8b225"]]},{"id":"be97cb5b.1448d8","type":"inject","z":"ade1a96c.062848","name":"Emulate data source","topic":"","payload":"{ \"result\" : [ { \"DimmerLevels\" : \"none\", \"IsDimmer\" : false, \"Name\" : \"voice_vorstalarm\", \"SubType\" : \"Switch\", \"Type\" : \"Light/Switch\", \"idx\" : \"1163\" }, { \"DimmerLevels\" : \"none\", \"IsDimmer\" : false, \"Name\" : \"voice_wasmachine\", \"SubType\" : \"Switch\", \"Type\" : \"Light/Switch\", \"idx\" : \"1149\" }, { \"DimmerLevels\" : \"none\", \"IsDimmer\" : false, \"Name\" : \"voordeurbel\", \"SubType\" : \"Switch\", \"Type\" : \"Light/Switch\", \"idx\" : \"1182\" }, { \"DimmerLevels\" : \"none\", \"IsDimmer\" : false, \"Name\" : \"vriezer\", \"SubType\" : \"Switch\", \"Type\" : \"Light/Switch\", \"idx\" : \"469\" }, { \"DimmerLevels\" : \"none\", \"IsDimmer\" : false, \"Name\" : \"wasmachine\", \"SubType\" : \"Switch\", \"Type\" : \"Light/Switch\", \"idx\" : \"976\" }, { \"DimmerLevels\" : \"none\", \"IsDimmer\" : false, \"Name\" : \"wii_lan_ip\", \"SubType\" : \"AC\", \"Type\" : \"Lighting 2\", \"idx\" : \"288\" } ], \"status\" : \"OK\", \"title\" : \"GetLightSwitches\" }","payloadType":"json","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":762,"y":72,"wires":[["b296fea1.9a217"]]},{"id":"b296fea1.9a217","type":"change","z":"ade1a96c.062848","name":"find Lantaarn","rules":[{"t":"set","p":"find","pt":"msg","to":"Lantaarn","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":958,"y":72,"wires":[["9b19d12b.8b225"]]},{"id":"e2330b3e.b54a18","type":"inject","z":"ade1a96c.062848","name":"Emulate data source","topic":"","payload":"{ \"result\" : [ { \"DimmerLevels\" : \"none\", \"IsDimmer\" : false, \"Name\" : \"voice_vorstalarm\", \"SubType\" : \"Switch\", \"Type\" : \"Light/Switch\", \"idx\" : \"1163\" }, { \"DimmerLevels\" : \"none\", \"IsDimmer\" : false, \"Name\" : \"voice_wasmachine\", \"SubType\" : \"Switch\", \"Type\" : \"Light/Switch\", \"idx\" : \"1149\" }, { \"DimmerLevels\" : \"none\", \"IsDimmer\" : false, \"Name\" : \"voordeurbel\", \"SubType\" : \"Switch\", \"Type\" : \"Light/Switch\", \"idx\" : \"1182\" }, { \"DimmerLevels\" : \"none\", \"IsDimmer\" : false, \"Name\" : \"vriezer\", \"SubType\" : \"Switch\", \"Type\" : \"Light/Switch\", \"idx\" : \"469\" }, { \"DimmerLevels\" : \"none\", \"IsDimmer\" : false, \"Name\" : \"wasmachine\", \"SubType\" : \"Switch\", \"Type\" : \"Light/Switch\", \"idx\" : \"976\" }, { \"DimmerLevels\" : \"none\", \"IsDimmer\" : false, \"Name\" : \"wii_lan_ip\", \"SubType\" : \"AC\", \"Type\" : \"Lighting 2\", \"idx\" : \"288\" } ], \"status\" : \"OK\", \"title\" : \"GetLightSwitches\" }","payloadType":"json","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":762,"y":168,"wires":[["24406a14.15c486"]]},{"id":"24406a14.15c486","type":"change","z":"ade1a96c.062848","name":"find voordeurbel","rules":[{"t":"set","p":"find","pt":"msg","to":"voordeurbel","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":968,"y":168,"wires":[["9b19d12b.8b225"]]}]
