Reading GPIOs issue
Hello again,
Still crawling the learning curve so pls, bear with me.
I'm reading 5 GPIOs lines and displaying them as LEDs.
However, only one of them responds to the changes.
I run a python loop to physically check the lines and they're ok.
The outputs are connected to external resistors and pulled high so, a short causes to read 0 otherwise, 1.
The question is, how do I troubleshoot this situation in node-red?
And, why is the widget telling me that it "stopped"? Stopped from what if, in theory, should be a continous read.
TIA
Make sure you set the RPi's internal ones (as set in the node) HIGH as well, or at least as NONE (floating)
BTW, in case you do have... I don't think you should have a GPIO-IN and GPIO-OUT for same pin
Yes, it's set to NONE. Thx.
No, they're not. One set is dedicated to the relays and the other, to the LEDs. Thx
As a guess.... it hasn't yet connected (or properly read) the status of that GPIO
It may be a board related issue. I'm running node-red on a zero-w. Will change to Rpi4 and see what happens. Thx.
Don't run that at the same time as node red, I suspect that two applications cannot use the pin at the same time.
Stop node red and Start it again in a terminal and post the startup log please. Copy/paste, not screenshot. Use the</> button at the top of the forum entry window when pasting.
Here it is. Thx.
OLD nodejs 0 :
NEW nodejs  :
Started : Fri 1 Oct 00:04:31 CEST 2021
Running for user pi at /home/pi
Failed to stop nodered.service: Unit nodered.service not loaded.
Found global nodes:   :
WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
Reading package lists...
Building dependency tree...
Reading state information...
Package 'nodered' is not installed, so not removed
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Package 'nodejs-legacy' is not installed, so not removed
Package 'nodejs' is not installed, so not removed
Package 'npm' is not installed, so not removed
Versions: node:v14.17.6 npm:6.14.15
npm WARN using --force I sure hope you know what you are doing.
Now install Node-RED
/usr/bin/node-red -> /usr/lib/node_modules/node-red/red.js
/usr/bin/node-red-pi -> /usr/lib/node_modules/node-red/bin/node-red-pi
> bcrypt@5.0.1 install /usr/lib/node_modules/node-red/node_modules/bcrypt
> node-pre-gyp install --fallback-to-build
node-pre-gyp ERR! install response status 404 Not Found on https://github.com/kelektiv/node.bcrypt.js/releases/download/v5.0.1/bcrypt_lib-v5.0.1-napi-v3-linux-arm-glibc.tar.gz
node-pre-gyp WARN Pre-built binaries not installable for bcrypt@5.0.1 and node@14.17.6 (node-v83 ABI, glibc) (falling back to source compile with node-gyp)
node-pre-gyp WARN Hit error response status 404 Not Found on https://github.com/kelektiv/node.bcrypt.js/releases/download/v5.0.1/bcrypt_lib-v5.0.1-napi-v3-linux-arm-glibc.tar.gz
make: Entering directory '/usr/lib/node_modules/node-red/node_modules/bcrypt/build'
  CC(target) Release/obj.target/nothing/../node-addon-api/nothing.o
  AR(target) Release/obj.target/../node-addon-api/nothing.a
  COPY Release/nothing.a
  CXX(target) Release/obj.target/bcrypt_lib/src/blowfish.o
  CXX(target) Release/obj.target/bcrypt_lib/src/bcrypt.o
  CXX(target) Release/obj.target/bcrypt_lib/src/bcrypt_node.o
  SOLINK_MODULE(target) Release/obj.target/bcrypt_lib.node
  COPY Release/bcrypt_lib.node
  COPY /usr/lib/node_modules/node-red/node_modules/bcrypt/lib/binding/napi-v3/bcrypt_lib.node
  TOUCH Release/obj.target/action_after_build.stamp
make: Leaving directory '/usr/lib/node_modules/node-red/node_modules/bcrypt/build'
+ node-red@2.0.6
added 292 packages from 372 contributors in 349.729s
2.0.6
Now create basic package.json for the user and move any global nodes
Running npm rebuild
Installing extra nodes: node-red-node-pi-gpio@latest node-red-node-random@latest node-red-node-ping@latest node-red-contrib-play-audio@latest node-red-node-smooth@latest node-red-node-serialport@latest :
> @serialport/bindings@9.2.4 install /home/pi/.node-red/node_modules/@serialport/bindings
> prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
prebuild-install WARN install No prebuilt binaries found (target=14.17.6 runtime=node arch=arm libc= platform=linux)
make: Entering directory '/home/pi/.node-red/node_modules/@serialport/bindings/build'
  CXX(target) Release/obj.target/bindings/src/serialport.o
../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)’:
../src/serialport.cpp:78:69: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
   uv_queue_work(uv_default_loop(), req, EIO_Open, (uv_after_work_cb)EIO_AfterOpen);
../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’:
../src/serialport.cpp:135:71: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
   uv_queue_work(uv_default_loop(), req, EIO_Update, (uv_after_work_cb)EIO_AfterUpdate);
../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)’:
../src/serialport.cpp:175:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
   uv_queue_work(uv_default_loop(), req, EIO_Close, (uv_after_work_cb)EIO_AfterClose);
../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)’:
../src/serialport.cpp:215:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
   uv_queue_work(uv_default_loop(), req, EIO_Flush, (uv_after_work_cb)EIO_AfterFlush);
../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’:
../src/serialport.cpp:271:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
   uv_queue_work(uv_default_loop(), req, EIO_Set, (uv_after_work_cb)EIO_AfterSet);
../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Get(Nan::NAN_METHOD_ARGS_TYPE)’:
../src/serialport.cpp:316:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
   uv_queue_work(uv_default_loop(), req, EIO_Get, (uv_after_work_cb)EIO_AfterGet);
../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE GetBaudRate(Nan::NAN_METHOD_ARGS_TYPE)’:
../src/serialport.cpp:366:76: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
   uv_queue_work(uv_default_loop(), req, EIO_GetBaudRate, (uv_after_work_cb)EIO_AfterGetBaudRate);
../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)’:
../src/serialport.cpp:412:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
   uv_queue_work(uv_default_loop(), req, EIO_Drain, (uv_after_work_cb)EIO_AfterDrain);
../src/serialport.cpp: At global scope:
../src/serialport.cpp:433:28: warning: unnecessary parentheses in declaration of ‘ToParityEnum’ [-Wparentheses]
 SerialPortParity NAN_INLINE(ToParityEnum(const v8::Local<v8::String>& v8str)) {
../src/serialport.cpp:452:30: warning: unnecessary parentheses in declaration of ‘ToStopBitEnum’ [-Wparentheses]
 SerialPortStopBits NAN_INLINE(ToStopBitEnum(double stopBits)) {
In file included from ../../../nan/nan.h:58,
                 from ../src/./serialport.h:13,
                 from ../src/serialport.cpp:1:
/home/pi/.cache/node-gyp/14.17.6/include/node/node.h:758:43: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
       (node::addon_register_func) (regfunc),                          \
/home/pi/.cache/node-gyp/14.17.6/include/node/node.h:792:3: note: in expansion of macro ‘NODE_MODULE_X’
   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
../src/serialport.cpp:486:1: note: in expansion of macro ‘NODE_MODULE’
 NODE_MODULE(serialport, init);
  CXX(target) Release/obj.target/bindings/src/serialport_unix.o
../src/serialport_unix.cpp: In function ‘int setup(int, OpenBaton*)’:
../src/serialport_unix.cpp:176:60: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1005 [-Wformat-truncation=]
     snprintf(data->errorString, sizeof(data->errorString), "Error %s Cannot open %s", strerror(errno), data->path);
../src/serialport_unix.cpp:176:13: note: ‘snprintf’ output 20 or more bytes (assuming 1043) into a destination of size 1024
../src/serialport_unix.cpp: In function ‘void EIO_Open(uv_work_t*)’:
../src/serialport_unix.cpp:86:60: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1003 [-Wformat-truncation=]
     snprintf(data->errorString, sizeof(data->errorString), "Error: %s, cannot open %s", strerror(errno), data->path);
../src/serialport_unix.cpp:86:13: note: ‘snprintf’ output 22 or more bytes (assuming 1045) into a destination of size 1024
  CXX(target) Release/obj.target/bindings/src/poller.o
  CXX(target) Release/obj.target/bindings/src/serialport_linux.o
  SOLINK_MODULE(target) Release/obj.target/bindings.node
  COPY Release/bindings.node
make: Leaving directory '/home/pi/.node-red/node_modules/@serialport/bindings/build'
npm notice created a lockfile as package-lock.json. You should commit this file.
+ node-red-node-ping@0.3.1
+ node-red-node-smooth@0.1.2
+ node-red-node-pi-gpio@1.2.3
+ node-red-node-serialport@0.14.1
+ node-red-contrib-play-audio@2.5.0
+ node-red-node-random@0.4.0
added 80 packages from 51 contributors in 169.258s
Now add the shortcut and start/stop/log scripts to the menu
Now add systemd script and configure it for pi
ln: failed to create symbolic link '/usr/bin/python': File exists
Now add launcher to top bar, add cpu temp example, make sure ping works
The user `pi' is already a member of `gpio'.
Memory  : 1.4G
Finished:  Fri  1 Oct 00:16:12 CEST 2021
@Colin Hi, have you seen anything interesting in that log?
I'm almost done with my project, but I'm still not clear on how and when the inputs are read on a Rpi.
Node-red is started via service and runs on the background. Meaning I can go on and use Python/PHP to read/write to GPIOs?
So, when are the inputs read actually? I understand when the user logs in the UI page till he/she logs out, right? If so, is it safe to say that the GPIOs used to read the signals are free-to-be-used till then and node-red wouldn't/doesn't clash with other applications?
I appreciate some inside on this.
TIA
It would seem to me that as long as Node-Red is running, the rpi-gpio in/out nodes are watching the GPIOs for state changes (or controlling the states), and thus possibly not a good idea to also have another process doing the same (lest there be a conflict in whether a pin be input, output, pullup/down, etc.).
The UI (dashboard) is another process altogether and not a dependency in reading or writing to GPIO from the appropriate nodes.
That isn't the log from starting node red, that is the installer log, I think.
In terminal, run
node-red-stop
node-red-start
As @Gunner says, node red is attached to the ports all the time node red is running. Node red doesn't read an input pin, the pin, effectively, tells node red whenever it's state changes.
I run gpio allreadall before, during and after node-red execution and it's clear that the used GPIOs are are not released by node-red (even with the browser off) thus not available to other applications.
If you have a flow that does something useful with your system when a pin is triggered (sets off an alarm if a window is opened for example), you would not want the alarm to be de-activated just because you did not have a browser open.
rpi-gpio nodes are browser agnostic. As long as Node-Red is running, those nodes are linked to their respective GPIO.
AFAIK this is normal behavior for all other coded routines (python, etc.) that do not release the GPIO, as you wouldn't want some other code messing around with them either.
I suppose you could experiment with disabling a rpi-gpio node when you want to use it with some other code. :thinking: Not sure if that would work for a dynamic adjustment, or only after a Deploy.
