Reading Timeout error when using contrib-bacnet
When try to read Bacnet Simulator Device using Yet Bacnet tool and Node Red using contrib-bacnet, there is a Timeout error message, in the PPT attached file are the steps to replicate the scenario.
PD: The simulation Yet Bacnet software can be downloaded from:
Any suggestion will be welcome.
Regards
Aland
Solved !!! Now i can read and write to Bacnet Simulator (Yet) using Node REd.
ABVSolved!!!
Could you pls send some screenshots?
Hi Kevin
attached the requested information
regards
Aland
(Attachment Conexion_BACNET.pptx is missing)
(Attachment Conexion_BACNET.pdf is missing)
