Rebuild curl command in Node-RED
I guess a typical beginner's question: I have a curl command like this:
curl -d "message=TEST" -X POST http://xxxx.xxx
How do I rebuild this in Node-RED? Looks that simple but I didn't manage to get it running, yet... Wanted to use a http node for that but how to configure it and what code do I need to set the payload correctly? At least this
msg.headers={ 'Content-Type': 'application/x-www-form-urlencoded'};
msg.payload = 'message=test';
doesn't work as well as
msg.payload ={message:'test'};
Thanks for any help...
The POST section in the CURL manual shows what is going on with the -d param
https://curl.haxx.se/docs/manual.html
This translates into a POST request with the payload set to "message=TEST"
I don't think that any other headers would be required since you aren't providing them with curl.
Oh no, it really was a beginner's fault... I forgot to set the HTTP request to "POST"...
So this code works:
msg.payload ="message=Test";
Without the Content-Type setting it doesn't... For whatever reason...
If anyone is interested: this code was built to work with the "Text Nachricht" skill from Amazon... Just take this code into a function, use the HTTP Request Node, enter the URL you got from the skill, change Method to "POST" and you're done... Then you get a nice notification on all your Echo devices, the same as you get when you expect a delivery from Amazon...
THANKS
