Hi team,
i try to use a TCP nodes to send and receive data in the local network.
for this, i try a simple application to see the result.
i want to send a mod-bus command for an mod-bus flex getter using a function "the attached image", but i couldn't receive the same message sent.
any idea !?
Thanks !
Not entirely certain what you are doing here but you have misspelled address. Maybe that is the problem?
thanks for your reply !
I fixed "address" it wasn’t the problem.
To summarize, by sending a string with "TCP out "(example "hello") I receive "hello" in TCP in.
I want to send the mod-bus command using function and TCP out..... **msg.payload = { 'fc': 3, 'unitid': 1, 'address': 0 , 'quantity': 1 }** , but I receive numbers in TCP in (buffer) or a [ object Object] if i use template after the TCP in.
I think there’s a conversion to be made?
exept string, how I can receive any kind of messages in "TCP in"
set the TCP in node to string?
then feed that into a JSON node (assuming the text you receive is valid JSON) to get a proper JS object where you can access the values.
