Hey there,
i was wondering if its possible to use RED.events.emit('myEvent',callback) inside a function node?
EDIT
does not look like it's available
EDIT2
i just created a custom node which emits a nodeRED event
still a solution inside the function node or any other core nodes would be preferred.
Isnt this what multiple outputs on a function are for?
How are you to planning on receiving these events - in another function node with RED.events.on("myEvent",function(){})?
Pretty sure that goes against the whole visual wiring design.
You need to be careful making use of RED.events since this is used internally by Node-RED. It would be easy to end up with a clashing event name and that could be super hard to diagnose.
Funnily enough I had a brief discussion with Dave about that the other day.
You might want to create your own event listener, it is pretty easy as it is a standard Node.js library.
Hey thanks for the Info with the clash possibillity.
I'll keep it in mind.
Yes it is nothing for every user. Im working on a project extending nodered for my company. And we are using a node with a c++ compiled code inside which establishes a communication with an company protocol. These nodes are sharing the same lib.
So it can be possible that 2 different nodes using internaly the same c++ client.
I needed a way to inform all nodes that the global configuration file has been changed. So that they can disconnect and reestablish the connection with new configuration
In that case, I recommend creating your own event handler, that will be much safer and really no harder.
This package, while not specifically Node-RED (it works anywhere but I import it and use it in Node-RED, I'll probably get round to writing a proper node-red node one day!) makes extensive use of events.
I have already implemented an own Emitter based in the nodejs emitter class
since you were recommending this and it makes absolutely sense!
