I really have no idea what I am doing
I would like to use suncalc to get the sunset and sunrise times for a day.
I installed suncalc in node red and npm. The sunrise node in node red works ok. I added SunCalc:require("suncalc") to my settings .js and tried calling SunCalc in my function node but all I get is "ReferenceError: SunCalc is not defined". Could someone shed a little light here?
Why not use the node-red-node-suncalc node direct ? Check the flows.nodered.org website
That would be great if I knew how
How do I get the sunset and sunrise time from node-red-node-suncalc?
By reading the node documentation, searching the forum.
Thank you, very helpful
How did you use it in your function node?
Note: https://discourse.nodered.org/t/how-to-share-code-or-flow-json/506
I tried
var times = SunCalc.getTimes(new Date(), 51.5, -0.1);
and
var times = global.get(SunCalc.getTimes(new Date(), 51.5, -0.1));
Both returned "ReferenceError: SunCalc is not defined"
You'd need to be a bit more specific about what you've tried.
The documentation for how to add new modules to the Function node is here: Redirecting…
From what you say, I assume your SunCalc:require("suncalc") line is inside the functionGlobalContext block in the settings file.
I also assume you've actually installed the suncalc module in ~/.node-red.
In your Function node you would then do:
var SunCalc = global.get('SunCalc');
var times = SunCalc.getTimes(....)
Your suggestion works, as you knew it would.
Yes, I was attempting to follow https://nodered.org/docs/writing-functions#loading-additional-modules but zero experience with javascript and node red was killing me.
My only programming knowledge is from 22 years of C on HP/UX.
If you do it that way, you don't need the node installed.
When using a node, you generally expect that the data it adds is attached to the msg object and you can then pick it up in the next node downstream. This is a generally preferred approach than adding weight to the global variable object.
