Refreshing ui_table
When I click twice on the Error button, why does it show only one entry in the table, and after a manual refresh, why does it show both entries?
How to fix it?
[{"id":"471994f81dc05b58","type":"ui_table","z":"8d0978fa5349c413","group":"group-id","name":"MessagesTable","order":22,"width":"0","height":"0","columns":[{"field":"timestamp","title":"Date / Time","width":"","align":"center","formatter":"plaintext","formatterParams":{"target":"_blank"}},{"field":"message","title":"Message","width":"","align":"center","formatter":"plaintext","formatterParams":{"target":"_blank"}}],"outputs":0,"cts":false,"x":800,"y":480,"wires":[]},{"id":"345ff202eb8658fd","type":"debug","z":"8d0978fa5349c413","name":"debug 2521","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":780,"y":520,"wires":[]},{"id":"8aa0b57b96b18d73","type":"function","z":"8d0978fa5349c413","name":"updateTable","func":"var timestamp = new Date().getTime();\nvar date = new Date(timestamp);\nvar readableDate = date.toLocaleString();\n\nvar messageContent = \"Error\";\n\nvar newRow = {\n    timestamp: readableDate,\n    message: messageContent\n};\n\nvar messages = flow.get('messages') || [];\n\nmessages.unshift(newRow);\n\nif (messages.length > 5) {\n    messages.length = 5;\n}\n\nflow.set('messages', messages);\n\nmsg.payload = messages;\n\nvar controlMsg = {ui_control: {callback: \"update\"}};\ndelete msg.socketid\nreturn [msg, controlMsg];","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":590,"y":520,"wires":[["471994f81dc05b58","345ff202eb8658fd"]]},{"id":"43ed59b3babe136a","type":"function","z":"8d0978fa5349c413","name":"resetTable","func":"flow.set('messages', []);\nmsg.payload = [];\ndelete msg.socketid\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":590,"y":480,"wires":[["471994f81dc05b58"]]},{"id":"634583e49ca39726","type":"link in","z":"8d0978fa5349c413","name":"link in 4","links":["3e9c8b726253b695"],"x":455,"y":520,"wires":[["8aa0b57b96b18d73"]]},{"id":"e39debd06002e510","type":"ui_template","z":"8d0978fa5349c413","group":"group-id","name":"Reset","order":10,"width":3,"height":1,"format":"<md-button class=\"vibrate filled touched smallfont rounded\" style=\"background-color:#616A6B\"   ng-click=\"send({payload: 'Hello World'})\"> \n    Reset<br/>\n</md-button> \n\n","storeOutMessages":false,"fwdInMessages":false,"resendOnRefresh":true,"templateScope":"local","className":"","x":430,"y":480,"wires":[["43ed59b3babe136a"]]},{"id":"8365569f07a9e36f","type":"ui_template","z":"8d0978fa5349c413","group":"group-id","name":"Error","order":2,"width":3,"height":3,"format":"<md-button class=\"vibrate filled touched bigfont rounded\" style=\"background-color:#c0392b\" ng-click=\"send({payload: 2})\"> \n    Error<br/>\n</md-button> \n\n","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":true,"templateScope":"local","className":"","x":210,"y":520,"wires":[["3e9c8b726253b695"]]},{"id":"3e9c8b726253b695","type":"link out","z":"8d0978fa5349c413","name":"link out 6","mode":"link","links":["634583e49ca39726"],"x":305,"y":520,"wires":[]},{"id":"group-id","type":"ui_group","name":"Default","tab":"tab-id","order":1,"disp":true,"width":"6","collapse":false},{"id":"tab-id","type":"ui_tab","name":"Home","icon":"dashboard","order":1,"disabled":false,"hidden":false}]
Have you looked at the ui-table examples, you will find them in editor.
Press ctrl I > examples > ui-table
Take a look at commands on how to add a row.
Did you mean the example on that site?
Ctrl+i or Ctrl+L seems not to be working properly (is it 'i' or 'L'?).
Additionally, I have implemented that function (to add row), but it appears not to solve my problem.
var controlMsg = {
    ui_control: {
        callback: 'update',
        tabulator: {
            addRow: newRow
No, in the node-red flow editor press control I or select import in the side menu
The command flow has examples of adding rows.
