Regex help node-red
Hi. Trying to learn regex to use in a change node. I have succeeded to get the expression right but don't make it to work in node-red. Probably some easy misstake but I'm stuck.
Hi Nicas ,
I believe you need to enclose you regex expression between /<regex>/
So the expression should be :
$match(payload, /(ID):((\d?)\d)_(\d+)_(\d+)/)
