Hi
what is wrong concerning this Node-Red-Log:
What is the flow on that pi trying to do?
There are several functions, DoorBell (mgtt and remote-access) and garden irrigation
some other question to get a feel of what you have
1 - What version of NR and node.js (you can get this from the startup log)
2 - What OS and version are you running on the Pi?
3 - What version of MQTT are you running?
4 - what device is the MQTT broker running on?
5 - Are any Docker containers involved?
6 - Did this just start appearing?
7 - have you made any changes recently?
Hi Paul
thank you very much for your support
Sevgilerimizle mit sonnigen Grüssen kind regards
Max Müller
Tekirova Mah.
Phaselis CAD No. 8
07995 Kemer / Antalya
CEP +90 (536) 242 6883
Home +90 (242) 821 4962
max.r.mueller@gmail.com
Max, which version of mosquito have you got installed?
Do you have and debug nodes in your flow? If so, are they named?
I see ‘debug1’ in the logs and wonder if that is from a debug node you have.
mosquitto 1.5.7
yes, I have several Debug-Nodes in divers Flows, but all „closed“ until one together with the „Remote-Node“
also I observe the Debug-messages in Node-Red, but there no messages are coming
now I have named this debug-node with „Remote-Control"
Müller Max
is that Eclipse Mosquitto
yes, it is Eclipse Mosquitto
learning by doing - I get this MQTT - Broker by a tutorial as an Open Source MQTT v3.1/v3.1.1 Broker
pi@raspi01:~ $ mosquitto -v
1657431917: mosquitto version 1.5.7 starting
1657431917: Using default config.
1657431917: Opening ipv4 listen socket on port 1883.
1657431917: Error: Address already in use
pi@raspi01:~ $
Müller Max
None of those messages in the log look like node-red messages. It looks like something to do with your SSH connection(s) or network setup. Are they still showing up?
@TotallyInformation Julian, do you have any insite into what those messages in the log are?
I also think this has nothing directly to do with Node-Red - it must be by the SSH remonte-access - but in ll other system-log's on the Mac I couldn’t finde any entry's
the RPi is „headless“ so I can see the Log by Terminal-SSH-connection only
on the second RPi (also headless), I don’t have all this messages there - and it is also an SSH-connection on the same kind
Müller Max
