Removal of extensions in strings and converting to number for a two-point control
your functions are referencing msg.temp1 etc, they needed to reference the incoming payload from the openhab2 in nodes.
But why not just join the messages as below, replace injects with openhub2 nodes
[{"id":"f62322f0.ae0c38","type":"inject","z":"b2964c3aa7426115","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"23 °C","payloadType":"str","x":240,"y":160,"wires":[["742592b4.5eed0c"]]},{"id":"742592b4.5eed0c","type":"change","z":"b2964c3aa7426115","name":"","rules":[{"t":"set","p":"topic","pt":"msg","to":"temp1","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":420,"y":220,"wires":[["fa678a58.c21848"]]},{"id":"fa678a58.c21848","type":"join","z":"b2964c3aa7426115","name":"","mode":"custom","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":true,"timeout":"","count":"2","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":590,"y":280,"wires":[["ff4f2b84c8d03171"]]},{"id":"ff4f2b84c8d03171","type":"change","z":"b2964c3aa7426115","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"$number($trim($split(payload.temp1,\"°C\")[0])) - $number($trim($split(payload.temp2, \"°C\")[0])) > 0","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":760,"y":280,"wires":[["40d8a5b513354c8d"]]},{"id":"34d9f5fe.34070a","type":"change","z":"b2964c3aa7426115","name":"","rules":[{"t":"set","p":"topic","pt":"msg","to":"temp2","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":420,"y":280,"wires":[["fa678a58.c21848"]]},{"id":"40d8a5b513354c8d","type":"debug","z":"b2964c3aa7426115","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":970,"y":280,"wires":[]},{"id":"1564eaff.715645","type":"inject","z":"b2964c3aa7426115","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"20 °C","payloadType":"str","x":240,"y":240,"wires":[["34d9f5fe.34070a"]]}]
