You need a way to distinguish between A and B, perhaps using msg.topic.
Then you need a way to get A and B into the same message, either using a join node or context storage.
Finally you need the values to be numbers not strings.
Ok, the string was my mistake. It is correct now. For the rest can you give me a code example. I'm not very good with node red
Just a hint:
One option:
"id": "32311aa6846c5342",
"type": "change",
"z": "ad5eb12b388e5d52",
"name": "Connect to Payload A",
"rules": [
"t": "set",
"p": "ValueA",
"pt": "flow",
"to": "payload",
"tot": "msg"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 420,
"y": 400,
"5d0b9f3abf8da0b1"
"id": "03f4aca5b398a77e",
"type": "change",
"name": "Connect to Payload B",
"rules": [
"t": "set",
"p": "ValueB",
"pt": "flow",
"to": "payload",
"tot": "msg"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 420,
"y": 440,
"5d0b9f3abf8da0b1"
"id": "5d0b9f3abf8da0b1",
"type": "function",
"name": "Substract",
"func": "var payloadA\nvar payloadB\n\npayloadA = flow.get(\"ValueA\"||0);\npayloadB = flow.get(\"ValueB\"||0);\nmsg.payload = payloadA - payloadB;\nreturn msg;",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 660,
"y": 420,
"7f8252d4dd3a5681"
"id": "7f8252d4dd3a5681",
"type": "debug",
"name": "result",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "payload",
"targetType": "msg",
"statusVal": "",
"statusType": "auto",
"x": 810,
"y": 420,
[{"id":"93f16891d794e03b","type":"join","z":"ac30d9279e67c57b","name":"","mode":"custom","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":false,"timeout":"","count":"2","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":570,"y":320,"wires":[["e9111659cebc98f5"]]},{"id":"70b47bac5cae85b0","type":"inject","z":"ac30d9279e67c57b","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"one","payload":"50","payloadType":"num","x":390,"y":280,"wires":[["93f16891d794e03b"]]},{"id":"cb134e7c5a77d728","type":"inject","z":"ac30d9279e67c57b","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"two","payload":"30","payloadType":"num","x":390,"y":360,"wires":[["93f16891d794e03b"]]},{"id":"e9111659cebc98f5","type":"change","z":"ac30d9279e67c57b","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.one-payload.two","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":760,"y":320,"wires":[["bf32970f8c0d987a"]]},{"id":"bf32970f8c0d987a","type":"debug","z":"ac30d9279e67c57b","name":"debug 230","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":950,"y":320,"wires":[]}]
