Remove the key part from a JSON string
Hi Everyone,
I'm new to Node Red and I'm trying to use it to read out around 30 rows of data from an SQL server database and import that data into a google sheet.
I'm stuck on converting the JSON string I'm getting from my SQL query into a JSON string the google sheet node will accept.
The string from the SQL looks something like this:
[{"ID":1,"Description":"First","Total":100,"GroupID":3},{"ID":2,"Description":"Second","Total":131,"GroupID":2}]
But to get that data into Google sheets I have to remove the key so it looks like this
[["1","First","100","3"],["2","Second","131","2"]]
Is there an easy way to do this or do I have to write a script inside a function node to do it?
Are you sure it is a string? I would have expected it to be a JavaScript object.
Asuming you mean Javascript object
Here are three examples
[{"id":"8dc3265970cd0547","type":"inject","z":"b9860b4b9de8c8da","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"[{\"ID\":1,\"Description\":\"First\",\"Total\":100,\"GroupID\":3},{\"ID\":2,\"Description\":\"Second\",\"Total\":131,\"GroupID\":2}]","payloadType":"json","x":330,"y":140,"wires":[["bb07fd5c10612f36","956aa217d92944a8","e925a44cbb4a53c0"]]},{"id":"bb07fd5c10612f36","type":"change","z":"b9860b4b9de8c8da","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"$$.payload.[$.*]","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":500,"y":140,"wires":[["083833d08ec38286"]]},{"id":"956aa217d92944a8","type":"split","z":"b9860b4b9de8c8da","name":"","splt":"\\n","spltType":"str","arraySplt":1,"arraySpltType":"len","stream":false,"addname":"","x":350,"y":200,"wires":[["cda2454120e5e59b"]]},{"id":"e925a44cbb4a53c0","type":"function","z":"b9860b4b9de8c8da","name":"function 21","func":"msg.payload = msg.payload.map(obj => Object.values(obj))\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":350,"y":280,"wires":[["083833d08ec38286"]]},{"id":"083833d08ec38286","type":"debug","z":"b9860b4b9de8c8da","name":"debug 328","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":790,"y":140,"wires":[]},{"id":"cda2454120e5e59b","type":"split","z":"b9860b4b9de8c8da","name":"","splt":"\\n","spltType":"str","arraySplt":1,"arraySpltType":"len","stream":false,"addname":"","x":470,"y":200,"wires":[["e0932a902820ce5f"]]},{"id":"e09848e55151b735","type":"join","z":"b9860b4b9de8c8da","name":"","mode":"auto","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":"false","timeout":"","count":"","reduceRight":false,"x":790,"y":240,"wires":[["083833d08ec38286"]]},{"id":"e0932a902820ce5f","type":"change","z":"b9860b4b9de8c8da","name":"","rules":[{"t":"set","p":"parts.type","pt":"msg","to":"array","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":650,"y":200,"wires":[["bb2830e8b8f0baed"]]},{"id":"bb2830e8b8f0baed","type":"join","z":"b9860b4b9de8c8da","name":"","mode":"auto","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":"false","timeout":"","count":"","reduceRight":false,"x":670,"y":240,"wires":[["e09848e55151b735"]]}]
If it is a JSON (string) then you can use a JSON node to convert from string to object.
Yes apologies it was a javascript object.
Thanks for your solution it works perfectly!
Just need to get my head around how each solution works.
