Restart of mqtt client
Hi all: I run nodeRed + the Mosquitto broker.
My problem:
The Mosquitto send the mqtt message only if the value changes e.g. a number from a slider in the dashboard. I use that value in a client (C++) for anything. However when the client restart the mosquito still does not send any mqtt >> the variable in the client remains 0.
Any idea how to "motivate" the mosquitto to poste the values of the scopes?
Thanks a lot!
If you send the MQTT message with the retain flag set - then when the client reconnects the broker will resend the last message on that topic.
Pefect!
Thanks a lot :slightly_smiling_face:
b.r. Alois
