Returns function value
Hi, everybody,
I need your help because I’m trying to create a rock, papers, cisors game with the help of the phone sensors and sending values not another but I want to display who won. I can’t return the value because of the function, it never returns any value at all I can’t tell who won. I’ll give you my code ( sorry it’s in French). Hopefully you can help me.
var msgEleve1 = {payload: msg.payload};
var msgEleve2 = {payload: msg.resultat2};
function comparer(choix1, choix2) {
  if (choix1 === choix2) {
    return 'Egalité !';
  } else if (choix1 === 'pierre') {
    if (choix2 === 'ciseaux') {
      return 'pierre';
    } else if (choix2 === 'feuille') {
      return 'feuille';
  } else if (choix1 === 'feuille') {
    if (choix2 === 'pierre') {
      return 'feuille';
    } else if (choix2 === 'ciseaux') {
      return 'ciseaux';
  } else if (choix1 === 'ciseaux') {
      return 'pierre';
      return 'ciseaux';
var resultat=comparer(msgEleve1,msgEleve2);
if (resultat == 'égalité') {
    msg.resultat='Egalité'
  } else if (resultat == msgEleve1) {
      msg.resultat='Eleve 1 a gagné'
  } else {
      msg.resultat='Eleve 2 a gagné'
You need to be sure what is going into the function is what you expect.
For example, your function comparer has no final else and will likely be falling through.
Also in your code, msgEleve1 & msgEleve2 are objects with a .payload property - cant compare objects like this if (choix1 === choix2) { so instead, take the string & compare that instead.
try this - see if it highlights your issue...
var msgEleve1 = msg.payload || "";
var msgEleve2 = msg.resultat2 || "";
const validChoices = ["pierre","feuille","ciseaux"];
if(!validChoices.includes(msgEleve1)) {
    node.warn(`msgEleve1 '${msgEleve1}' is not valid`)
    return null;
    node.warn(`msgEleve2 '${msgEleve2}' is not valid`)
    return null;
        return 'Egalité !';
            return 'pierre';
            return 'feuille';
            return 'feuille';
            return 'ciseaux';
            return 'pierre';
            return 'ciseaux';
var resultat = comparer(msgEleve1, msgEleve2);
if (!resultat) {
    return null; //halt flow
    msg.resultat = 'Egalité'
    msg.resultat = 'Eleve 1 a gagné'
} else {
    msg.resultat = 'Eleve 2 a gagné'
return msg; //return msg to next node
Thank you for your help. But I’m a beginner in this area so I don’t see how to compare from the string at all. Can you help me more?
Doesn't the example posted by @Steve-Mcl show you how to do it?
There are a few issues here @bperard:
  1. égalité is an impossible returned value:
    i.e., if (resultat == 'égalité') {
comparer returns Egalité ! not égalité
  1. comparer function is expecting two strings as input, not two objects.
  1. There is no check for valid inputs. Unexpected outcomes will result if something other than feuille, ciseaux, or pierre are used as inputs.
Points 2 & 3 were addressed by @Steve-Mcl. The first point was not.
It needs to be:
if (resultat == 'Egalité !') {
After that, the script he provided should work as you expect.
Thank you for your help. I finally got what I wanted. Good evening to you.
