RFXCom node problems
hello folks, I am trying to install rfxcom's nodes, node-red-contrib-rfxcom. But get the same notifications every time.
does anyone have an idea what this could be
2020-08-24T13:39:14.972Z Install : node-red-contrib-rfxcom 2.11.2
2020-08-24T13:39:15.065Z npm install --no-audit --no-update-notifier --no-fund --save --save-prefix="~" --production node-red-contrib-rfxcom@2.11.2
2020-08-24T13:39:37.721Z [out]
2020-08-24T13:39:37.721Z [out] > @serialport/bindings@8.0.8 install /config/node-red/node_modules/@serialport/bindings
2020-08-24T13:39:37.721Z [out] > prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
2020-08-24T13:39:38.818Z [err] prebuild-install
2020-08-24T13:39:38.819Z [err]
2020-08-24T13:39:38.819Z [err] WARN
2020-08-24T13:39:38.820Z [err] install
2020-08-24T13:39:38.820Z [err] No prebuilt binaries found (target=12.17.0 runtime=node arch=arm64 libc=musl platform=linux)
2020-08-24T13:39:41.554Z [err] gyp
2020-08-24T13:39:41.555Z [err]
2020-08-24T13:39:41.555Z [err] ERR! build error
2020-08-24T13:39:41.556Z [err] gyp
2020-08-24T13:39:41.557Z [err] ERR!
2020-08-24T13:39:41.557Z [err] stack
2020-08-24T13:39:41.557Z [err] Error: not found: make
2020-08-24T13:39:41.557Z [err] gyp ERR!
2020-08-24T13:39:41.557Z [err] stack at getNotFoundError (/usr/lib/node_modules/npm/node_modules/which/which.js:13:12)
2020-08-24T13:39:41.557Z [err] stack at F (/usr/lib/node_modules/npm/node_modules/which/which.js:68:19)
2020-08-24T13:39:41.558Z [err] stack
2020-08-24T13:39:41.558Z [err] at E (/usr/lib/node_modules/npm/node_modules/which/which.js:80:29)
2020-08-24T13:39:41.558Z [err] gyp
2020-08-24T13:39:41.558Z [err] ERR! stack
2020-08-24T13:39:41.558Z [err] at /usr/lib/node_modules/npm/node_modules/which/which.js:89:16
2020-08-24T13:39:41.558Z [err] stack at /usr/lib/node_modules/npm/node_modules/isexe/index.js:42:5
2020-08-24T13:39:41.558Z [err] at /usr/lib/node_modules/npm/node_modules/isexe/mode.js:8:5
2020-08-24T13:39:41.558Z [err] at FSReqCallback.oncomplete (fs.js:167:21)
2020-08-24T13:39:41.559Z [err] gyp
2020-08-24T13:39:41.559Z [err] ERR! System Linux 4.19.127-v8
2020-08-24T13:39:41.559Z [err] ERR! command
2020-08-24T13:39:41.560Z [err] "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
2020-08-24T13:39:41.560Z [err] gyp ERR!
2020-08-24T13:39:41.560Z [err] cwd /config/node-red/node_modules/@serialport/bindings
2020-08-24T13:39:41.560Z [err] ERR! node -v
2020-08-24T13:39:41.560Z [err] v12.17.0
2020-08-24T13:39:41.560Z [err] ERR! node-gyp -v v5.1.0
2020-08-24T13:39:41.560Z [err] not ok
2020-08-24T13:39:42.533Z [err] npm
2020-08-24T13:39:42.533Z [err] ERR! code ELIFECYCLE
2020-08-24T13:39:42.533Z [err] npm ERR!
2020-08-24T13:39:42.534Z [err] errno 1
2020-08-24T13:39:42.538Z [err] npm
2020-08-24T13:39:42.538Z [err] ERR! @serialport/bindings@8.0.8 install: prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
2020-08-24T13:39:42.538Z [err] npm ERR! Exit status 1
2020-08-24T13:39:42.539Z [err] ERR! Failed at the @serialport/bindings@8.0.8 install script.
2020-08-24T13:39:42.539Z [err] npm ERR!
2020-08-24T13:39:42.539Z [err] This is probably not a problem with npm. There is likely additional logging output above.
2020-08-24T13:39:42.588Z [err]
2020-08-24T13:39:42.589Z [err] npm ERR! A complete log of this run can be found in:
2020-08-24T13:39:42.589Z [err] ERR!
2020-08-24T13:39:42.589Z [err] /root/.npm/_logs/2020-08-24T13_39_42_557Z-debug.log
2020-08-24T13:39:42.622Z rc=1
2020-08-24T13:40:28.532Z Install : node-red-contrib-rfxcom 2.11.2
2020-08-24T13:40:28.836Z npm install --no-audit --no-update-notifier --no-fund --save --save-prefix="~" --production node-red-contrib-rfxcom@2.11.2
2020-08-24T13:40:44.342Z [out]
2020-08-24T13:40:44.342Z [out] > @serialport/bindings@8.0.8 install /config/node-red/node_modules/@serialport/bindings
2020-08-24T13:40:44.342Z [out] > prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
2020-08-24T13:40:45.403Z [err] prebuild-install
2020-08-24T13:40:45.403Z [err] WARN
2020-08-24T13:40:45.404Z [err] install No prebuilt binaries found (target=12.17.0 runtime=node arch=arm64 libc=musl platform=linux)
2020-08-24T13:40:47.462Z [err] gyp
2020-08-24T13:40:47.463Z [err]
2020-08-24T13:40:47.463Z [err] ERR! build error
2020-08-24T13:40:47.465Z [err] gyp
2020-08-24T13:40:47.465Z [err] ERR!
2020-08-24T13:40:47.465Z [err] stack
2020-08-24T13:40:47.465Z [err] Error: not found: make
2020-08-24T13:40:47.465Z [err] at getNotFoundError (/usr/lib/node_modules/npm/node_modules/which/which.js:13:12)
2020-08-24T13:40:47.466Z [err] at F (/usr/lib/node_modules/npm/node_modules/which/which.js:68:19)
2020-08-24T13:40:47.466Z [err] gyp
2020-08-24T13:40:47.466Z [err] ERR! stack at E (/usr/lib/node_modules/npm/node_modules/which/which.js:80:29)
2020-08-24T13:40:47.466Z [err] gyp ERR!
2020-08-24T13:40:47.466Z [err] stack at /usr/lib/node_modules/npm/node_modules/which/which.js:89:16
2020-08-24T13:40:47.466Z [err] stack at /usr/lib/node_modules/npm/node_modules/isexe/index.js:42:5
2020-08-24T13:40:47.466Z [err] stack at /usr/lib/node_modules/npm/node_modules/isexe/mode.js:8:5
2020-08-24T13:40:47.467Z [err] gyp ERR!
2020-08-24T13:40:47.467Z [err] stack at FSReqCallback.oncomplete (fs.js:167:21)
2020-08-24T13:40:47.467Z [err] ERR! System Linux 4.19.127-v8
2020-08-24T13:40:47.468Z [err] gyp
2020-08-24T13:40:47.468Z [err] ERR! command
2020-08-24T13:40:47.468Z [err] "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
2020-08-24T13:40:47.468Z [err] gyp ERR! cwd /config/node-red/node_modules/@serialport/bindings
2020-08-24T13:40:47.468Z [err] node -v
2020-08-24T13:40:47.468Z [err] v12.17.0
2020-08-24T13:40:47.468Z [err] ERR! node-gyp -v
2020-08-24T13:40:47.468Z [err] v5.1.0
2020-08-24T13:40:47.469Z [err] ERR! not ok
2020-08-24T13:40:48.517Z [err] npm
2020-08-24T13:40:48.517Z [err] ERR! code ELIFECYCLE
2020-08-24T13:40:48.517Z [err] npm ERR!
2020-08-24T13:40:48.518Z [err] errno 1
2020-08-24T13:40:48.523Z [err] npm
2020-08-24T13:40:48.523Z [err] ERR! @serialport/bindings@8.0.8 install: prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
2020-08-24T13:40:48.524Z [err] ERR! Exit status 1
2020-08-24T13:40:48.524Z [err] npm
2020-08-24T13:40:48.524Z [err] npm ERR!
2020-08-24T13:40:48.524Z [err] Failed at the @serialport/bindings@8.0.8 install script.
2020-08-24T13:40:48.524Z [err] ERR! This is probably not a problem with npm. There is likely additional logging output above.
2020-08-24T13:40:48.564Z [err]
2020-08-24T13:40:48.565Z [err] npm
2020-08-24T13:40:48.566Z [err]
2020-08-24T13:40:48.566Z [err] ERR!
2020-08-24T13:40:48.568Z [err] A complete log of this run can be found in:
2020-08-24T13:40:48.570Z [err] npm ERR! /root/.npm/_logs/2020-08-24T13_40_48_540Z-debug.log
2020-08-24T13:40:48.603Z rc=1
I think this is similar...
perhaps it can help?
It looks like you need to install the build tools package on your Linux system
It depends on which OS you are using but probably you want the package build-essential
sudo apt install build-essential
