Hi, Thanks to your reply, I created the below code to login using REST API. But when I login I cannot access pages. I have verified I get the access_token and get role from it. Can you help or point what I am missing or doing wrong.
var request = require('request');
var jwt = require('jsonwebtoken');
const { valid } = require('semver');
module.exports = {
type: "credentials",
users: function (username) {
return new Promise(function (resolve) {
// Do whatever work is needed to check username is a valid
// user.
var valid = true;
if ('admin' != username || 'user' != username) {
valid = false;
if (valid) {
// Resolve with the user object. It must contain
// properties 'username' and 'permissions'
if ('admin' == username) {
var user = { username: "admin", permissions: "*" };
} else if ('user' == username) {
var user = { username: "user", permissions: "read" };
} else {
resolve(null);
resolve(user);
} else {
// Resolve with null to indicate this user does not exist
resolve(null);
authenticate: function (username, password) {
// Do whatever work is needed to validate the username/password
// combination.
console.log("Sending aunthentication request to keyclock");
var options = {
'method': 'POST',
'url': 'https://auth.example.com/auth/realms/MyRealm/protocol/openid-connect/token',
'headers': {
'Content-Type': 'application/x-www-form-urlencoded'
form: {
'grant_type': 'password',
'username': username,
'password': password,
'client_id': 'node-red',
'client_secret': 'my-secret',
'scope': ''
request(options, function (error, response) {
if (error) {
console.log("Error authenticating: " + error);
resolve(null);
return;
var bodyObj = JSON.parse(response.body);
var jwtObj = jwt.decode(bodyObj.access_token);
console.log("Got access_token");
console.log("role: "+jwtObj.roles[0]);
var user = null;
if (jwtObj.roles[0]=='admin') {
console.log("permissions: *");
user = { username: jwtObj.roles[0], permissions: "*" };
} else if (jwtObj.roles[0]=='user') {
console.log("permissions: read");
user = { username: jwtObj.roles[0], permissions: "read" };
resolve(user);
default: function () {
// Resolve with the user object for the default user.
// If no default user exists, resolve with null.
resolve({ anonymous: true, permissions: "read" });
EDIT: It tuns out it is saving username. I checked by logging it in users function, but I a returning admin and it is saving the actual username. Is there a way to use local storage??
// user.
console.log("Verfying user: "+username);
